Anyone want a nice XS825?
  • Crazcnuk
    • Aug 2006
    • 2980
    • Hinton, AB, Canada
    Ok. tried swapping the spark plug wires. #1 would then pop out the exhaust every few seconds. Whenever it did a couple of pops, blue smoke would come with it.
    #4 warmed up but not as fast as 2 or 3.
    I took the coils off and tested them. 2-3 coil tested 1.5 primary, nothing secondary. (this is the one that works)
    1-4 tested 1.5 primary 1500 secondary. (this is the one not working)
    I went and took the TEC coils off of the 79 parts bike, and put them on, but, so far, no spark at all. They are 2.4ohms primary, so I bypassed the ballast resistor.
    Then it started pouring rain, again.
    '05 ST1300
    • dbeardslee
      • Nov 2007
      • 4385
      • Maineville, OH
      Craz - did you mean 15,000 secondary? That would be right in spec. If it was 1500, you might try grafting some new wires into the old coils - it's pretty easy and it works. The 78-80 coils are a little easier to do, than the later model coils, so that's good. Sounds like you might be on to something.
      • MNS494
        • Jan 2010
        • 32
        • BOISE, ID
        I'm not a guru or even mechanichly inclined........but i had my number one popping... Occasionaly....and it went away when i adjusted the air/fuel mixture screw out five turns....the engine started reving up at 4 1/2 turns and the popping went away.....
        DENNIS
        1981 MNS..1980 CARBS , STOCK AIR BOX, FIVE 1/2" HOLES IN BACK OF MUFFLERS (SINCE COVERED UP WITH A BIG WASHER)
        1983 HONDA 350R
        1972 YAMAHA 250 MX
        196? MONTESA 250 ENDURO STRIPPED DOWN
        1967 BENEILI 125 ENDURO (NOWHERE NEAR BIG ENOUGH)
        • lvrsnr
          • 114
          • Kelso, Washington
          a valve that is too tight or slightly burnt will hold enough compression to idle well enough but once up to temperature or under a load does not and can give all the signs you are seeing. leak down test would be best. but lacking the equipment to do that. checking valve clearance and compression is the best course.
          Alias Larry R in Kelso WA
          When in dought, punch it.
          XS1100LG Precious current
          XS1100SF Ruby gone to a better home
          KZ900B MIA stolen (ALL bike thieves MUST GET OFF THE PLANET more politically correct ???)
          • Crazcnuk
            • Aug 2006
            • 2980
            Put the high perf coils off JD on tonight and now it runs on all 4.
            Much better with full power. I will change the carbs next, because #4 needle is broken off and I couldn't get the tip out. 2 and 3 were broken too, but I got those out.
            I will go with the 80-81 type carbs, much less to go wrong.
            '05 ST1300
            • dbeardslee
              • Nov 2007
              • 4385
              • Maineville, OH
              So does that mean it's not an 825 anymore ? Glad you're making headway.
              • Crazcnuk
                • Aug 2006
                • 2980
                Yeah, it's an 11 again. Now to start putting all the upgrades from the other on to it.
                Will take a while. First thing carbs.
                Then my new rear tire is in, will put it on the tubeless rim, which also has new bearings and seals.
                I have LOTS of things to transfer over.
                '05 ST1300
