Please help!!!
    • 8891
    Maybe this will help...
    • raqumup
      • Feb 2004
      • 94
      • Ashburn, VA
      where did you get that? that is exactly what i needed. i think this is the spot i was talking about, thanks man. i dont know if that is my problem or not but it is still good info to have.
      Troy
      79' XS1100SF
      • raqumup
        • Feb 2004
        • 94
        • Ashburn, VA
        well it helped me at least knock that off the list of posibilities. i was able to blow air down the needle valve hole and feel it coming out of the needle hole and those 3 holes, so they are clear.
        Thanks
        Does the (what is labeld as starter jet) do anything other than choke?
        79' XS1100SF
          • 8891
          Starter jet is for the fuel enrichment circuit, sort of like a choke, except it adds extra fuel instead of choking off air. Not sure if it contributes to anything other than cold starting. Diagram is courtesy of Topcat.
          • raqumup
            • Feb 2004
            • 94
            • Ashburn, VA
            OK!!! i put the old #1 carb that came with the bike and it ran so much better. i synced the carbs, off a little, and rode it around the block. if i let it idle for 5 sec. or so it will do the same thing it has been doing but not as bad, i can get throught it much easyer than befor, so i was right its the carbs, but i still dont know why, i need another #2 carb anyone have one they want to sell? thanks for all your advise, made me feel like i was not alone.
            79' XS1100SF
            • ManagerMike
              • Mar 2010
              • 445
              • S.E. Michigan
              Just a thought, you stated that you have cleaned the carbs repeatedly. Did you remove the float valve seats? My '78 has filter screens on the inlet side of the seats. Carbs 1 and 2 share a petcock from the tank and may both have clooged inlet screens. Again, just a thought.
              '78 E "Stormbringer"
              • raqumup
                • Feb 2004
                • 94
                • Ashburn, VA
                Yes I do know about the tiny screens at the fuel inlet and they are clean. But as I said in the last post. The old carb body seemed to fix the problem with #1 now I just need to get a carb body for #2 and I think I will be good to go. Bu thank you for the advise.
                Troy
                79' XS1100SF
                • raqumup
                  • Feb 2004
                  • 94
                  • Ashburn, VA
                  Hahahahaha!!!!!
                  I finnaly got a set of carbs. found'em on ebay. $120. they were nasty but i was able to clean them up and i used carb body #2 only and transfered the old parts, IT'S ALIVE!!!! I am so happy, i have been itching to ride, crappy thing is my state inspection is dead and i cant get one untill monday. i may just risk it and ride tommrow? thanks for all you help and support on this one.
                  79' XS1100SF
                  • XS1100_OEM4ME
                    • Mar 2009
                    • 1619
                    • Fort Myers, Florida
                    plugs
                    Great, ride!
                    1980 XS1100 Special
                    1990 V Max
                    1982 KZ750 LTD Twin
                    1974 CB750-Four
                    Past/pres Car's
                    • Rickrod3
                      • Jun 2009
                      • 721
                      • Oakland, New Jersey
                      Originally posted by raqumup
                      Yes that small hole in the carb bowls are clear. Just did a compression test
                      180 180 155 175 and I did a leakdown test
                      5% 5% 5% 3-4%. Keep in mind that the problem ones are the 180 and 180. As far as I can tell the spec is 142 with a max difference of 14. I know I am outside the difference but the one that is out works just fine. I am going to try to sync them I have the mercury tubes. I don't think that is it because I don't see how the can get out of sync from just sitting for 5-6 months but we shall see. Thanks for all the help guys I really appreciate it
                      Troy
                      I read here somewhere (TC I think pointed out) that higher than spec compression (without any mods) could be carbonized combustion chamber.
                      Maybe 1 & 2 carbs running richer causing rhe chamber to carbon up.
                      HTH
                      Rick
                      650SF
                      XS1100SG Project bike
                      • raqumup
                        • Feb 2004
                        • 94
                        • Ashburn, VA
                        yea i am aware of that as well but i did look down in each cylinder with a bore scope and that is not the case. i am sure it was the #1 and #2 carb bodies. that is all i swaped out and it runs fine now.
                        thanks
                        79' XS1100SF
                        • 79XS11F
                          • Jul 2006
                          • 3563
                          • Ottawa, Ont. Canada
                          Run a compression test and check the valve clearences.
                          Rob
                          KEEP THE RUBBER SIDE DOWN
                          1978 XS1100E Modified
                          1978 XS500E
                          1979 XS1100F Restored
                          1981 Suzuki GS1100
                          1983 Suzuki GS750S Katana
                          1983 Honda CB900 Custom
                          • yamtom
                            • 275
                            • Midland Michigan
                            Iirc
                            I believe that at least two of those holes go to the enrichment system, I believe the third one is to the pilot system.
                            Its funny how a couple of months can make uncertain the memory of this old fart.
                            I believe that I read that in Kats Karb info here on channel 11.
                            Bikes Now.
                            80 MNS 11 pods,georgefix kit,stock jets, HD Sporty muffs
                            79 XS 11 Special, Emgo pods, stock jets, with Pacifico fairing, hard bags, intact stock pipes Sold
                            83 Yammi Venture with custom footboards, 20k miles.
                            83 Yammi Venture parts bike
                            99 Valkyrie shield and bags 37k miles like new
                            08 ZX 14 Kawa Ninja 6k miles Sold
