79 xs fork tubes
  • cowboybob998
    • Mar 2009
    • 371
    • KC MO
    79 xs fork tubes
    Will 79 xs standard fork tubes work in 1980 special fork sliders ?
    Any one ever done this ?
    1979 xs1100 f
    142 main, 45 pilot, Jardeen crosover 4/2, no air box
    floats @ 25.7
    1979 xs1100 F
    1978 gl 1000 goldwing
    1981 gl 1100 goldwing
    !986 venture royale 1300
    Just an ol long haired country boy, come to town to spend some egg money
    when ya get bucked off, get back on
  • Geezer
    • May 2003
    • 2985
    • Willamina, Oregon 97229
    You could make them work but the bike wouldn't be safe to ride.
    Geezer
    • cowboybob998
      • Mar 2009
      • 371
      • KC MO
      Geezer
      Why would it not be safe to ride, it would change the rake and trail of the bike and that is what i want to do but I think it will still be in the limets of control, what i need to know if the forks will work in the fork sliders
      Thanks
      bob
      I will be puting the fork sliders on the 79 and useing the 79 frame and trees, I am trying to rake the front and lower it at the same time.
      1979 xs1100 f
      floats @ 25.7
      1979 xs1100 F
      • Geezer
        • May 2003
        • 2985
        They're about 4" shorter and you would have to use the standard springs too. The bike would be in a permanent state of nose dive...
        Geezer
        • Crazcnuk
          • Aug 2006
          • 2980
          • Hinton, AB, Canada
          Actually the std tubes are about 4" longer, and will make the front sit higher than stock. (they aren't actually longer, I don't think, but the axle goes under the std forks and part way up the back of the special forks.)
          You will have to lengthen the side stand too. I have a 79SF in my yard with std forks on it.
          '05 ST1300
            • 8894
            The Standard and Special tubes use a different bushing setup, it's not gonna work, BTDT.
              Yep, that's the real point. You could swap the entire fork setup, keeping the original trees, but the inner and outer fork tubes are not interchangeable between standards and specials.
              • Geezer
                • May 2003
                • 2985
                I wonder how DennyZ did it. He put special tubes in a standard then used the extra length above the top clamp to put on clip-ons...
                Geezer
                  He would have had to changed the bushings and such at the bottom of the tubes to the standard ones to work in the standard outer tubes. A mismatch will either bind or have too much slop depending on which way you go.
                  At least that is what I have read in here, I think it was when b_walker was replacing his bent forks.
                    • 8894
                    When I tried the Special tubes in the Standard legs, they would bind up and not slide smoothly at all. The Standard tubes have the absence of a lower bushing, while the Special tubes have a lower bushing, just like most other type damper rod forks. Maybe he just left the lower bushings off altogether.
                    • cowboybob998
                      • Mar 2009
                      • 371
                      • KC MO
                      thanks guys
                      I think I know what i need to do now.
                      I bought this parts bike with a good motor that had been wrecked the forks i think are bent, but i wanted to put the special front end on the standard trees, I may have some spare parts off this bike and would be willing to trade for some straight tubes, dont know yet need to get things apart and see what is hurt.
                      thanks yall
                      Bob
                      1979 xs1100 f
                      floats @ 25.7
                      1979 xs1100 F
                        • 8894
                        Bob, I have some extra Standard fork tubes in good shape. If you're interested, shoot me a PM.
