Rear Master.... Again
  • Toolmaker Tim
    • 671
    • South Bend, Indiana
    Carb Removal
    That fun project seems to be a ongoing part of XS ownership. I cut the top bracket off flush with the airbox to make it easier, relatively speaking. I have toyed with the idea of going to pods just to make carb removal easier.
    1979XS1100SF
    K&N's and drilled airbox
    Jardine 4in1
    Dunlop Elite 3's
    JBM slide diaphragms
    142.5 main jets
    45 pilot jets
    T.C.'s fusebox & SOFA
    750/850 FD mod.
    XV 920 Needle Mod.
    Venture Cam Chain Tensioner
    • dbeardslee
      • Nov 2007
      • 4385
      • Maineville, OH
      That's why I did it, and I never looked back. I did have to bump the mains one notch, as you've already pointed out. I also fabricate a little metal strap that runs from in-between #2 and #3, to the underside of where the air box strap used to go (hope that makes sense). When you get rid of the airbox, it's a good idea to add some support back there so your carb boots don't take a beating from them bouncing around.
      • Toolmaker Tim
        • 671
        I saw it.....
        but didn't make the connection between the xs pods and the next higher jet size. DUH! I'm starting to get my head wrapped around what is going on inside this bike again. When I parked the bike last fall I was fairly disquisted with it and let it set all winter. Of course not having any heat in the mancave helped. This winter was sort of cold. Must be the global warming!
        1979XS1100SF
        Jardine 4in1
        Dunlop Elite 3's
        142.5 main jets
        45 pilot jets
        750/850 FD mod.
        XV 920 Needle Mod.
        • Toolmaker Tim
          • 671
          I actually understood what you were trying to say about the carb brace. Something I was pondering myself. I think it might be bad to suddenly have your carbs pop out of their holders while rolling down the road!
          1979XS1100SF
          Jardine 4in1
          Dunlop Elite 3's
          142.5 main jets
          45 pilot jets
          750/850 FD mod.
          XV 920 Needle Mod.
            • 8893
            Tim, an easy mod for making the carbs easy to remove is....
            1. Lose the top bracket for the air box altogether.
            2. Cut the snorkel tube off 1" from it's base.
            3. Now after removing the lower piece of the air box and the filter, the top piece of the box can be easily removed prior to removing the carbs.
            I've done this to both my bikes, and there have been no problems, and it also breathes better in conjunction with drilling out the bottom piece in the center filter area.
            • Toolmaker Tim
              • 671
              Short Snorkel
              Yeah Phil, I cut that down also. Read it about doing it in a thread last year. It took me awhile to screw up my nerve to chop off a piece of my airbox, but in hindsight the engineers should have done it right at the start. I think I'll not be drilling holes in the airbox until I get the carbs right.
              1979XS1100SF
              Jardine 4in1
              Dunlop Elite 3's
              142.5 main jets
              45 pilot jets
              750/850 FD mod.
              XV 920 Needle Mod.
                • 8893
                With the holes drilled in the bottom, anything dropped thru the new snorkel opening (ex: a bolt) will fall right out the bottom usually. Good luck with your carbs, once they're dialed in, won't have to fool with them much any more.
                • thewiz
                  • Oct 2006
                  • 1115
                  • Wilksboro, NC
                  this link used to have photos ...
                  but it may help you with the master. Trick is rolling the seal inside out and then back to the correct position as it is pried up over the stopper on the piston.
                  80G Mini-bagger
                  Past XS11s
