One of my calipers has locked up. I tried to get the caliper off and it won't move? How can I get it unstuck and take it off?
1980 XS1100 Special dual front brakes
Crack the bleader screw to releave the pressure... Do a little searching on breaks, look in the maintenance section and you will find all kinds of tricks. Welcome to the forum.'79 XS11 F
Stock except K&N
'79 XS11 SF
Stock, no title.
'84 Chevy K-10 "Big Blue"
"What they do have is an implacable, unrelenting presence and movement that bespeaks massive power lurking behind paint and chrome. They don't wail like a screeching ninja, the don't rumble like a harley. They just growl like a spactic, stressed out badger waiting to rip your face off and eat your soul." Trainzz~RIP~ -
And after that remove the other one, and the back one, and both master cylinders, and clean according to all the tech tips. You can't be to sure when it comes to the brakes. I would say, if you have a problem with one, the rest need repair also. I had my rear freeze up, that's how i found out how dirty the system was.1980 XS1100LG Midnight
1991 Honda CBR1000F Hurricane
A cold beer and another one!Comment
I used a 1" wooden dowel and a drill press to press the piston INTO the caliper. After that, I re-attached it to the brake lines on the bike, bled the air out, and used the pressure from the master cylinder to press the piston out.
Compressed air can also be used instead of connecting it to the master cylinder again, but it's not as strong, and a lot more explosive when it pops out.
+1 on cleaning the entire system though. If one is dirty, the whole system propably is too.1980 XS850SG - Sold
-H. FordComment
A G clamp will also work to drive the piston it.1980 SG. (Sold - waiting on replacement)
"A man should look for what is, and not for what he thinks should be" Albert Einstien.Comment
Okay, thats a different story. Yes, open the nipple and bleed any pressure off. This will tell you if it's a pressure problem or a seized caliper. Take the caliper monting bolt out, if you havent already and try to work the caliper off the disk by rocking it back and forth, spray the disk with some WD-40 or something to provide some lube (make sure NOT to reuse the pads if you do). If no go, then you probably have no option but to try to pry it off. Be careful not to damage the disk, although they are pretty hard.
I've never had the problem but others have and I'm sure you will get further advice
Good Luck1980 SG. (Sold - waiting on replacement)
Once the pressure is bled off, you can use a piece of wood and a hammer to tap it off the rotor. Try to "walk" it off, tapping firmly on the upper edge, then the lower, repeating until it walks all the way off the edge. Don't twist the caliper sideways (left to right on the bike) or you may damage the rotor.1980 XS850SG - Sold
-H. FordComment
Good Luck
Over time the old MC spooges up, blocks the return, and locks you up. I did a rebuild on my front MC 5-6 years ago, but still never had teh bite I liked, the New MC plus SS lines gives it near 'stoppie' power ;-) I think the front MC for dual disks on Mikes XS is $68.
If you decide NOT to rebuild, but just push caliper back in, make sure you remove the dust boot carefully, and clean well so you dont damage the seal. Also, I use a C clamp to slowly push the piston back in.2005 FJR 1300 "Mission" (NON ABS)
1979 XS 1100 SF "Visitation" Owned since 1984 - SS Brake Lines, TKAT fork brace, Progressive Fork Springs.
1978 XS 750 D "Motivation" - 9" rear custom shocks, dropped front end, shaved seat
When Caged:2006 Jeep Commander, 1986 Cutlass 442, 1976 Porsche 912E (latest project)Comment
