Quick Wiring question - Project Nearly Complete
  • res1uqtp
    • May 2009
    • 84
    • East Central IL
    Hey guys:
    Finally after a year of going through these basket cases I think I may have a runner. More on that later this week as I just dropped in the motor last night ....
    I've got a question about a dark green lead that piggybacks off the cable that runs from the starter solenoid to the starter about 3" long and with a female small round pin type connector. I don't seem to have a matching lead on a component or the wiring harness. Is this just an auxiliary or some sort?
    My Stable:
    2006 Triumph Bonneville Black
    1979 Yamaha XS11 Special (2 of them)
    1982 Yamaha XS400 Heritage Special
    1981 Suzuki GS550 E
    1976 Honda CB550F Supersport
  • randy
    • Dec 2003
    • 4521
    Huh? From the starter solenoid to the starter is, like, 18" or so. If you mean it's a green lead running TO the starter, then it's the oil sender lead.
    • res1uqtp
      • May 2009
      • 84
      • East Central IL
      This guy right here .....
      My Stable:
      1981 Suzuki GS550 E
      • res1uqtp
        • May 2009
        • 84
        • East Central IL
        UGH .....
        I've got the damn thing on backwards don't it
        My Stable:
        1981 Suzuki GS550 E
        • CatatonicBug
          • 6117
          • Clinton, UT
          I don't have that green wire on either end of that lead. OFC, my solenoid is round too...
          • res1uqtp
            • May 2009
            • 84
            • East Central IL
            I have two of the 79 specials. Two have become ALMOST one. I looked at the other one and I have the same green wire but I've disassembled that one down past the point of knowing if it connected to anything or not ....
            My Stable:
            1981 Suzuki GS550 E
            • randy
              • Dec 2003
              • 4521
              Bug, you dont have that lead because you've got an 81, 3 ohm coils, no ballast.
              res1uqtp:
              IF you have a 78/79:
              That lead is the ballast bypass, goes to the TCI, RED/YELLOW lead.
              • res1uqtp
                • May 2009
                • 84
                • East Central IL
                FOUND IT!!!!
                Little sucker was hiding tucked back by the signal leads....
                Never would have found it without your help
                My Stable:
                1981 Suzuki GS550 E
