Swing arm hook thingy
  • LuckyEddie
    • 166
    • Middleville, Michigan
    Would any of you happen to know what the hook thingy on the end of the swing arm on the right side end is for?
    LuckyEddie
    1980 XS1100LG Midnight special
    1982 XV750J Virago
    1976 GL1000
    1978 GL1000 Supercharged
    1981 XV920RH (chain drive)
  • CatatonicBug
    • 6117
    • Clinton, UT
    It's for the shock tool that came in the stock tool kit. A piece of wire that hooks there, then under the fender, and around to the other side. It makes it so you can keep the swingarm up hight enough to remove the rear axel without removing the exhaust.
      There's two (or at least on my bike). The little tab welded near the pinch bolt has no use I can see, but the other one is for the 'tire change cable' required on the 'standards' (specials too?) to hold the swingarm up when removing the rear axle. This cable has a 'sling' that goes on the drive-side shock, two hooks that connect to the frame just below the seat, and the other end hooks to the hook. Install it when the bike is sitting with weight on the suspension, and when you pull it up onto the center stand, the cable keeps the swingarm high enough that you don't have to pull the mufflers to get the axle out.
      '78E original owner
      • brcree
        • Mar 2010
        • 388
        • S.C.
        Tab
        How cleaver those Japanese were!
        At this time:
        1985 Goldwing Innr.
        1976 cb 750 cafe racer
        2007 vtx 1300
        81 sx 1100 s h
        81 sx 400 special
        • rover
          • Jan 2004
          • 765
          • central WI (715)
          hook thingy
          This was an afterthought. They should have made the design so the axle could be removed without all the hoopla. They did on the Special, which was introduced in the second year of production. Oh well, hindsight is ALWAYS 20-20
          put something smooooth betwen your legs, XS eleven
          79 F (Blueballs)
          79 SF (Redbutt)
          81 LH (organ donor)
          79 XS 650S (gone to MC heaven)
          76 CB 750 (gone to MC heaven)
          rover has spoken
          • randy
            • Dec 2003
            • 4521
            It's there to hook the brake torque arm on. That will hold the brake caliper assembly suspended while you remove the wheel.
              • 8962
              I was clever too, I ground them off.
              • HobbyMan
                MeatHead Idiot "GURU"
                • Jul 2006
                • 1801
                • Colleyville, TX
                I like the design. If they didn't raise up the pipes on the standard, you wouldn't be able to take any fast corners without grinding your exhaust. The XS1100 is after all, a beautiful road racing machine.
                Acta Non Verba
