Alright, Tell me what these means
  • Eric_XJ
    • 56
    • Columbus, Ohio
    Rode up to the gas station tonight and back (less than 3 miles round trip)
    Checked the temps on the exhaust (Mac 2-1 turnouts) after about 2-3 min and this is what I got:
    1 - 188
    2 - 237
    3 - 249
    4 - 241
    I'm guessing I'm running lean on 1 ? What are the normal temps on this thing ?
    -Eric
    82 XJ1100
    Mods:
    Mac 4 to 2 with turn out's
  • XSokieSPECIAL
    • Jun 2009
    • 1631
    • Tulsa, OK
    Check your plugs, I'll bet your running rich on #1 and that plug is blacker than the others.
    Too much fuel will run cooler.
    Your not too far off though.
    • Montreux_Blue
      XS-XJ Guru (Deceased)
      • 1143
      Greg uses his tongue to tell the temp on his headers....
      Famous Myspace quote:
      • Eric_XJ
        • 56
        • Columbus, Ohio
        What kind of temps should I expect ? Am I too lean on the other 3 ? All 4 plugs look dark around the ring, but look tan-ish white.
        -Eric
        82 XJ1100
        Mods:
          My guess is those temps are in the normal range. As to no 1 and plug color, color sounds real good on all of them. Perhaps no 1 is only rich at idle. I'd not worry about it if the plugs look consitent and that good, and it feels like its running good.
          • XSokieSPECIAL
            • Jun 2009
            • 1631
            • Tulsa, OK
            My tongue is very useful in many ways.........ask your girlfriend!.....LOL....
              So she has trouble sleeping alot and calls you to talk her to sleep??
              • XSokieSPECIAL
                • Jun 2009
                • 1631
                • Tulsa, OK
                Heh heh heh....well....sometimes we talk.......dirty....LOL...
                • Montreux_Blue
                  • 1143
                  Hate to break it to you but we listen to you on speaker phone and mute it when we are laughing our azz off!!!!! Got it on tape too and sell those out of the trunk of the car!
                  • XSokieSPECIAL
                    • Jun 2009
                    • 1631
                    • Tulsa, OK
                    Like Don said, I think your pretty good.
                    How does it idle? Maybe try turning that #1 Idle mix screw in just a little.
                    Start at 1/4 turn and check it again, or if you know someone with a color tune that's the way to go.
                    • XSokieSPECIAL
                      • Jun 2009
                      • 1631
                      • Tulsa, OK
                      You sell those tapes at the same time your cruising around in that old car trying to lure little kids in there with you with candy?
                      I bet those tapes turn you on when you finally get one. Huh?...LOL...
                      There's a name for people like you in prison.......Mary...
                      • Eric_XJ
                        • 56
                        • Columbus, Ohio
                        That's the problem. It pops on accel and decel and does not idle well. it dies when the choke is off. I thought about changing the mix screw, but I'm trying to attack this logically. The plugs are the same that were on the bike when I got it. I'm going to change the plugs this weekend, guess I'll ride it and check em again. Just trying to get a feel for where I'm at.
                        -Eric
                        82 XJ1100
                        Mods:
                          Popping on decel is usually cured by properly adjusting the air/fuel mixture screws (colortune, or by ear). Try that, along with a proper sync, and then check the temps again.
                          • brcree
                            • Mar 2010
                            • 388
                            • S.C.
                            No 1 pipe
                            Hey Eric.....you may want to check and see if no. 1 air/fuel screw tip isn't broken off in the carb...I had two! All good info in here!
                            At this time:
                            1985 Goldwing Innr.
                            1976 cb 750 cafe racer
                            2007 vtx 1300
                            81 sx 1100 s h
                            81 sx 400 special
                            • XSokieSPECIAL
                              • Jun 2009
                              • 1631
                              • Tulsa, OK
                              If it's popping on acceleration like you said, it may NOT be a fuel problem.
                              Have you checked the pickup coils?
                              Make certain your not having an ignition problem, it can seem JUST like a carb problem.
                              I pulled and cleaned and adjusted my carbs......? times when I first got my XS thinking that's where the problem was.
                              I had a pickup coil wire going south that would make it act like a fuel problem.
