Different pilot jet sizes
    Originally posted by dbeardslee
    Nope - analog meter isn't precise enough - gotta be a digital. They're pretty inexpensive, though.
    I just bought a new one at Harbor Freight for $4.99. My old one ran on watch batteries, and those things cost more than the new meter!
    • blade
      • May 2009
      • 46
      • Nampa, Idaho
      I will have to get a DMM then.
      Not sure when I will be able to get one though.
      1978 XS1100 E work in progress. Bought in 1998 19xxx miles.
      1979 XS1100 F running. Bought May 2010 30xxx miles. 145 mains, 45 pilots, Ivan's v-stack mod, pods and 4-2 Jardine, 25.7mm floats.
      1979 XS1100 SF missing tank and seat. Top end dismantled.
      1989 xt600
      1984 Honda vt500
      1983 Honda cm250
      • blade
        • May 2009
        • 46
        • Nampa, Idaho
        Hi CatatonicBug.
        I heard that some of the cheaper dmm's can be inaccurate, so I am not sure how much to spend on one. I like to buy higher quality tools but with the current economy I don't have that luxury anymore.
        Have you had good results with the one you bought from Harbor Freight?
        1989 xt600
        1984 Honda vt500
        1983 Honda cm250
          #34
          Originally posted by blade
          Hi CatatonicBug.
          Well, I'm not looking for a tool that I will be using to make a living with. It's been fine so far, and reads voltage and ohms quite well IMO. It reads several other things as well, but that's all I've used it for. This is the one I got. They have a slightly more expensive one with a backlit display, but I haven't had a need for that option, so I didn't pay the extra $2.
          • randy
            • Dec 2003
            • 4521
            #35
            NOPE...analog is fine.
            • blade
              • May 2009
              • 46
              • Nampa, Idaho
              #36
              Thanks for the link. For $3.99 I should buy a few to have in other vehicles, or as backup's etc.
              At least it would be more accurate than my analog meter.
              1989 xt600
              1984 Honda vt500
              1983 Honda cm250
              • Stoffa
                • 9
                • Frenchs Forest, Australia
                #37
                4-5000 rpm stutter
                I also had a similar problem - not the carbs but Ignition not fully advancing.
                Put a timing light on it to check max advance, its a lot easier than pulling the carbs. If it is the advance there are quite a few fixes in these pages. Best of luck.
                Stoffa
                XS11 H '82
                XS2 '72
                XS2(US) '72
                XS650 '76
                XS650sp '79
                XS650sp '80
                GL1800 '06
                • dbeardslee
                  • 4385
                  • Maineville, OH
                  #38
                  I was just looking at my analog meter, and Randy's probably right. Make sure you zero it first, and look for a reading that's between 600 and 800 on the analog. On a digital the range is from 576-864 ohms, but I doubt that the scale on an analog meter is going to get that precise, but it should be close enough to tell if the pickup coil wires are OK. I don't think I'd trust the analog as much on the voltage readings though, only because you can't read the analog as precisely. What the heck - dmm's are cheap and come in real handy. Any hardware store should have them relatively inexpensively, or HF if you've got one close.
                  • blade
                    • May 2009
                    • 46
                    • Nampa, Idaho
                    #39
                    Hi Stoffa.
                    Good idea, I had better check that too.
                    1989 xt600
                    1984 Honda vt500
                    1983 Honda cm250
                    • blade
                      • May 2009
                      • 46
                      • Nampa, Idaho
                      #40
                      Hi Randy.
                      I think i'll still get a DMM. I haven't had one before so it would be nice to try.
                      Also I have have seen DMM's that can check temperatures too.
                      1989 xt600
                      1984 Honda vt500
                      1983 Honda cm250
                      • blade
                        • May 2009
                        • 46
                        • Nampa, Idaho
                        #41
                        "I don't think I'd trust the analog as much on the voltage readings though, only because you can't read the analog as precisely."
                        I agree, especially with my analog. It sounds like a DMM would make more sense, at least for me.
                        1989 xt600
                        1984 Honda vt500
                        1983 Honda cm250
                        • blade
                          • May 2009
                          • 46
                          • Nampa, Idaho
                          #42
                          "Put a timing light on it to check max advance"
                          I just realized I need to get a timing light too.
                          Any one have any suggestions on a reasonably priced one?
                          1989 xt600
                          1984 Honda vt500
                          1983 Honda cm250
                            • 8930
                            Yep, Harbor Freight....
                            http://www.harborfreight.com/xenon-t...ight-3343.html
                            • psycoreefer
                              • Feb 2008
                              • 1557
                              • Minden, NV
                              #44
                              yup, I've got that one, works fine for limited occasional use, must have been on sale when I got mine though, I think I only paid 7.
                              1979 xs1100 Special -
                              My Bike:
                              [link is broken]
                              • blade
                                • May 2009
                                • 46
                                • Nampa, Idaho
                                #45
                                Looks good to me. Like I would know. I have never had one before.
                                The price is right anyway.
                                Thanks
                                1989 xt600
                                1984 Honda vt500
                                1983 Honda cm250
