Different pilot jet sizes
  • blade
    • May 2009
    • 46
    • Nampa, Idaho
    I got another xs a couple weeks ago. It is a 79 standard.
    The PO had added pod filters to it and 4-2 slash cut pipes.
    It would start up and idle, but it was rough, like it was starving for fuel on #1.
    When I took it for a test ride it pulled hard up to around 4 1/2 to 5000 rpm then
    it would splutter and refuse to push through.
    As soon as I bought the bike I pulled the carbs to clean.
    I found that #1 pilot jet was broken off so managed to get it out by taping a really small screwdriver gently into the jet hole and backing it out. When I looked at it I noticed it was clogged with old fuel and it was a 42.5. The other three are 45s. I had a spare 42.5, so I used it to replace the broken one until I get another 45.
    The main jets are all 137.5 . I also had to fix and replace 3 broken mixture screw tips that were stuck in the little holes.
    It starts up great now with no hesitation, idles nicely all pipes are getting hot.
    It now pulls even harder up to 4 1/2 to 5000 but does the same thing.
    I suspect the cheap pods are obstructing the air jet.
    I have also ordered 145. mains and four new 45 pilots from Mikesxs to compensate for the pods and slash cut pipe.
    I am going to put some K&n pods on since I already have them.
    Will it cause any damage to ride it with one odd pilot jet while I am waiting for my new ones to be delivered?
    1978 XS1100 E work in progress. Bought in 1998 19xxx miles.
    1979 XS1100 F running. Bought May 2010 30xxx miles. 145 mains, 45 pilots, Ivan's v-stack mod, pods and 4-2 Jardine, 25.7mm floats.
    1979 XS1100 SF missing tank and seat. Top end dismantled.
    1989 xt600
    1984 Honda vt500
    1983 Honda cm250
  • dbeardslee
    • 4385
    • Maineville, OH
    It's not going to cause damage, but it probably won't run as well as it could. You'll probably have to go several turns farther out on the mixture screw on the one with the 42.5. 45's on the pilots and 145's on the mains sounds about right with your mods. Sounds like your carbs could use a good cleaning too.
    • bchaffin
      • 47
      • Warrensburg, Missouri
      I just got my first xs a month ago and it does the same thing yours is doing. It runs fine till I get into the higher rpm range then it spits and sputs and won't go. I have those pod filters which I am going to change and I thought maybe it needs rejetted. Let me know if you get something figured out. I am putting bigger jets in this weekend so hopefully that fixes it.
      1980 Yamaha XS1100 Std
      4 into 1 exhast, pod filters
      2003 Triumph Thruxton
      • blade
        • May 2009
        • 46
        • Nampa, Idaho
        Hi, dbeardslee.
        I cleaned the carbs out really well but I realized that i didn't take out the emulsion tubes and clean them. Maybe that is the problem with bike hitting a wall at around 5000 rpm.
        1989 xt600
        1984 Honda vt500
        1983 Honda cm250
        • blade
          • May 2009
          • 46
          • Nampa, Idaho
          Hi bchaffin. I will let you know how it goes. I am also thinking of doing the v-stack mod with my old air box hoses that I read about here.
          1989 xt600
          1984 Honda vt500
          1983 Honda cm250
          • blade
            • May 2009
            • 46
            • Nampa, Idaho
            rear wheel
            I noticed there is a little bit of side to side play on the rear wheel.
            The shaft looks like it is too far in on the side with the pinch bolt, the little hole on the end of the shaft looks too far into the swingarm.
            I assumed that it is bottoming out too soon and leaving a small gap.
            I have to get a torque wrench before I can check it.
            Any Ideas?
            1989 xt600
            1984 Honda vt500
            1983 Honda cm250
            • dbeardslee
              • 4385
              • Maineville, OH
              I've seen them hit a wall at 5k when the plugs/screws over the pilot jet tunnels are missing. It's a mid range problem, so it could be connected to the emulsion tubes or slide needles and diaphragms. You might check the make sure you're needles are on the center grove, and that you don't have any holes in your diaphragms. Might also check your pickup coil wires. 5k is right about where you reach maximum advance, so the wires are stretched as far as they go at that point. And it never hurts to do a complete electrical test of your ignition system with a dmm. Many times ignition problems will fake you out into thinking it's the carbs.
              Got a camera? Pics of the rear end would be helpful.
              • blade
                • May 2009
                • 46
                • Nampa, Idaho
                Thanks for the reply.
                I checked over the diaphragms and didn't see any holes, I will check again though. I will check the needles too as i can't remember if they were in the center or not.
                I will do a check of the wires on the pickup coil too.
                I noticed if I keep it at slower gradual throttle opening it seems to rev higher but if I give it a handfull it hits the wall.
                I am going to find my daughters camera and get a pic.
                1989 xt600
                1984 Honda vt500
                1983 Honda cm250
                • blade
                  • May 2009
                  • 46
                  • Nampa, Idaho
                  The screws are all there covering the pilot jet tunnel.
                  1989 xt600
                  1984 Honda vt500
                  1983 Honda cm250
                  • blade
                    • May 2009
                    • 46
                    • Nampa, Idaho
                    I took a pic but I couldn't figure out how to upload it. It asked for a URL.
                    1989 xt600
                    1984 Honda vt500
                    1983 Honda cm250
                    • blade
                      • May 2009
                      • 46
                      • Nampa, Idaho
                      A private space for your group's photos and videos. Share, react, and relive moments together. Available on iOS, Android, and desktop. Free for new sign-ups.
                      1989 xt600
                      1984 Honda vt500
                      1983 Honda cm250
                        Looks like you have the brake rotors from a Midnight Special on there. I can't tell if the wheels are gold too though... The other black parts look like a MNS too. Is that a MNS? You don't have one listed in your signature.
                        • blade
                          • May 2009
                          • 46
                          • Nampa, Idaho
                          HiCatatonicBug.
                          I am not sure if the PO put the rear end off a different model or not.
                          Is there a difference apart from color?
                          1989 xt600
                          1984 Honda vt500
                          1983 Honda cm250
                            Originally posted by blade
                            HiCatatonicBug.
                            Not really, for the '80 (LG) model. The '81 (LH) had a few things that were significantly different (linked brakes, swirly wheels, different calipers). Can you post a pic of the whole bike??
                            • dbeardslee
                              • 4385
                              • Maineville, OH
                              Sounds like you might have a 16" rear wheel. Here's the diagram for the back wheel on a '78 E, but it seems to me like there's something else you have to do to put a special wheel on a standard. Maybe someone who's done it will weigh in.
