Different pilot jet sizes
  • blade
    replied
    I took the petcocks off and did the vacuum valve mod. Next I removed the vacuum tube to #4 carb boot and put tube between the two petcocks to each vacuum port. I capped the #4 car boot.
    I took it for a ride and it does seem better but at times it will hang at around 3k rpm when I pull the clutch in and take a while to return to idle.
    I checked the throttle cable where it meets the carbs, it is fully seated, when I twist the throttle and it snaps back fully with a little slack in the cable.
    Tomorrow I am going to borrow a friends vacuum synch. Hopefully that is where the problem is. After the synch I will adjust the mixture screws.
    I have noticed that at idle I can smell gas coming from the exhaust pipes, it is not a very strong smell but I did notice it. I have read some other posts that say it is normal as the xs's run rich at idle but I didn't know what to think. It could be from carbs being slightly out of synch.
    It is running great apart from the idle/rpm issue.
    I really want to ride it more but I am nervous about doing some kind of damage to the engine.
    Leave a comment:
  • blade
    replied
    Originally posted by psycoreefer
    I think he's saying when he shuts the throttle the RPMS remain "high" for a little while before coming back to idle, could be caused by the extra fuel, a vacuum leak, or out of synch carbs.
    Yes, that is what I meant.
    I am quite sure it is not the carbs being synched because when I unhook the vacuum tube and block off the hole on the #4 carb manifold I don't have the over rev problem.
    Leave a comment:
  • psycoreefer
    replied
    Leave a comment:
  • dbeardslee
    replied
    When you say over run, are you saying gas is coming out of the carb bells? That's a sign of two things - one, your octopus isn't shutting off the fuel flow, and two, your fuel valves aren't sealing in the carbs.
    Leave a comment:
  • blade
    replied
    oops double post
    Leave a comment:
  • blade
    replied
    yup, fix that vacuum line pulling fuel, that would really be throwing #4 off. Also if you didn't you should do a vacuum synch on the carbs, will make it much smoother.
    I am glad yo think so too. Does that make sense that the over run would be associated with the leaky vacuum?
    I haven't done a vacuum synch yet, but I did synch them with a thin wire to get them close. It seems pretty close to me, but I won't know till I do a vac synch.
    Leave a comment:
  • psycoreefer
    replied
    Leave a comment:
  • blade
    replied
    Half the time the el-cheapos are the best. I might have to pick one up - then I can stop borrowing my brothers . When you check the timing, you'll usually get better results if you hook the timing light to an external power source - like a battery charger or a car battery (not in the car, at least not while the car is running.) You want to plug the vacuum advance and keep it at 1100 rpms if you're setting/checking the timing, but if you want to see how far it's advancing, then don't (duh ).
    Thanks for all the good advice, I am glad I can go back through the posts because it would be hard to remember everything.
    Leave a comment:
  • blade
    replied
    Well, I put the new plugs in, NGK BR6ES instead of the br8's the PO had in.
    I took it for a ride and now I have power, lots of it and all the way through the rev band. I am happy that the jet change, the emulsion tube clean and the plugs change have fixed the 4-5k rpm problem.
    On a side note I am getting a over run on the rpm's sometimes when I cut the throttle.
    I think it is because of the leaky vacuum on the petcock is sucking fuel into the #4 cyl.
    I am going to do the vacuum bypass mod and block the prime so I will have an off position. Hopefully that is why I am getting the over run.
    I think it is, because after I get on the throttle there seems to be a lot of fuel going to #4 from the petcock, when I release the throttle after a while the fuel disappears from the vacuum tube and the rpm's return to normal.
    Leave a comment:
  • dbeardslee
    replied
    Leave a comment:
  • blade
    replied
    Looks good to me. Like I would know. I have never had one before.
    The price is right anyway.
    Thanks
    Leave a comment:
  • psycoreefer
    replied
    yup, I've got that one, works fine for limited occasional use, must have been on sale when I got mine though, I think I only paid 7.
    Leave a comment:
    replied
    Yep, Harbor Freight....
    http://www.harborfreight.com/xenon-t...ight-3343.html
    Leave a comment:
  • blade
    replied
    "Put a timing light on it to check max advance"
    I just realized I need to get a timing light too.
    Any one have any suggestions on a reasonably priced one?
    Leave a comment:
  • blade
    replied
    "I don't think I'd trust the analog as much on the voltage readings though, only because you can't read the analog as precisely."
    I agree, especially with my analog. It sounds like a DMM would make more sense, at least for me.
    Leave a comment:
