Hey everyone....little update. Just completed some little odds and ends things on 'Sunshine, and decided to take it to work this morning.....until this morning, the bike had only seen 10-15 mile trips while chasing demons and eliminating gremlins.....
This mornings trip (65 miles) allowed me to see some other areas of attention...BUT i am VERY happy
to say..... the beast runs well, plenty of get up and go..even from 80 mph.... the longer it ran, the better it responded....had some clutch slipping yesterday...adjusted it...now no high speed/rev slipping....good throttle response (color/carb tune has been done) will check plugs when i get home to see condition....
Speedo acting a bit funny....odometer works(i think accurate), but speed slow to react...both up and down, and makes a bit of noise.
guessing it needs some lube...i have spares to swap out...will see. tach wants to jump all over every once in a while.....not sure whats going on there.... will need new shoes (tires) as the front is iffy...rear is getting thin in the skin...but no wet roads right now....
I knew the plastic front fender would have to go byebye....no fork brace (yet..sitting on my workbench, but fork seals need replaced, so not installing yet until ready to put back on bike)...just went down to parking lot..and so far no tell signs of leaks ANYWHERE
So again, im happy. And thanks to everyone!!! You WILL be hearing from me soon on the forkseals, tires im sure....being i dont have ANY tire tools..and less time...i may drop the beast off and have them mount/balance them for me!!!
to say..... the beast runs well, plenty of get up and go..even from 80 mph.... the longer it ran, the better it responded....had some clutch slipping yesterday...adjusted it...now no high speed/rev slipping....good throttle response (color/carb tune has been done) will check plugs when i get home to see condition....Speedo acting a bit funny....odometer works(i think accurate), but speed slow to react...both up and down, and makes a bit of noise.
......So again, im happy. And thanks to everyone!!! You WILL be hearing from me soon on the forkseals, tires im sure....being i dont have ANY tire tools..and less time...i may drop the beast off and have them mount/balance them for me!!!
