Heh heh heh! Techie fight!
The ported vacuum advance signal in the XS100 is a simple analog throttle position sensor that is most useful at small, part-throttle positions. It reacts faster and more precisely to small changes in part-throttle position than manifold vacuum.
As the throttle is opened the timing is advanced as the edge of the throttle plate moves across and uncovers the vacuum advance port to help burn the lean part-throttle mixture provided by the idle and transfer ports and increase power.
When the throttle is closed there is no vacuum advance because no one in their right mind cares about making good power at zero throttle except Toyota.
At higher speeds and larger throttle openings the fuel/air mixture is no longer a part-throttle lean mixture and further advancing the ignition timing will create lots of heat and high cylinder pressures. The engine will work against itself so the total amount of vacuum advance allowed has to be limited.
Okay, 35 MPH in 5th gear is only about 2,000 RPM. Let's see what would happen!
As the throttle opens past ~1/4 travel, the area of intake manifold pressure starts to extend up the carburetor throat ahead of the throttle plate to the carburetor venturi slides. The velocity of the air flowing through carburetor starts to increase and the idle and transfer ports begin to get some help in the form of more fuel from the main jet and more air from the carburetor venturi as the carburetor slides and the jet needle begin to rise.
If manifold vacuum stays above 6 inHG with the throttle wide open the vacuum advance is essentially 'all in' and will add to the centrifugal advance as the engine RPMs increase.
'78E Vacuum Advance
0* @ 50 mmHg [1.97 inHg]
16* @ 150mmhg [5.91 inHg]
As the speed of the engine continues to increase above 2,000 RPM and the mechanical advance starts to work, manifold vacuum will continue to rise and the vacuum advance will stay fully advanced unless the throttle is closed.
'78E Mechanical Advance
1* @ 2150
26* @ 4750
At 35 MPH in 5th gear the engine is only turning about 2,000 RPM. The mechanical advance has not yet begun to operate and there is only static ignition timing plus vacuum advance. If the throttle is cracked wide open, vacuum advance might drop, briefly, but at 2150 RPM the mechanical advance will begin to go to work.
The engine will accelerate, slowly, and as the main jets begin to provide additional fuel and the carburetor slides open to provide more air it will produce more power and accelerate faster until the blue light begins to flash and the real fun begins.
'78E Vacuum Advance
1* @ 2150
26* @ 4750
