Can't remember where the rubber gaskets go for the headlight uprights. I found two on the shelf but I've gone brain dead.
anybody with a 79 sf
mack
79 XS 1100 SF Special
HERMES
original owner
81 XS 1100 LH MNS
SPICA
78 XS 11E
IOTA
https://youtu.be/wB5Jfbp6SUc
https://youtu.be/RaI3WYHSuWA
Frankford, Ont, Canada
613-398-6186Tags: None -
They go below the headlight brackets on top of the fork cover nameplate. When I installed mine, I found I needed to loosen the top pinch bolts and the bolt holding the top triple tree in place.Life is what happens while your planning everything else!
78 XS750 -
They go under the cover with the Yamaha logo on it on the bottom part of the triple tree .BDF Special
Dyno tuned to 98 hp at the rear wheel.Comment
You can find what you're looking for here http://www.yamaha-motor.com/sport/parts/home.aspxBDF Special
Not quite
Getting there though. Finished with the wiring and and bucket last night. Doing the front MC and caliper rebuilds today and by "miller" time I should have the front wheel on. Depends on how the bleeding goes. After that it's just the exhaust, engine guard and finally putting the carbs back together. While my compression numbers improved they are still under what they should be. I'm going to bench sync the carbs and run it for a week or so to see if the rings free up before I colour and carb tune it. At this point I'd be happy if it starts even if it runs poorly.mack
HERMES
original owner
81 XS 1100 LH MNS
SPICA
78 XS 11E
IOTA
613-398-6186Comment
