Spark Plug Caps?
    Spark Plug Caps?
    Do I have to use 5K plug caps or can I run no resistance caps? and if i can change to the no resistance caps would it make a difference?
    Thanks
    • 8794
    You can use any resistance cap or non resistance type. The resistance type is for radio supression, it doesn't affect the operation of the coils. IMHO, less resistance is better.
    07 Triumph Tiger 1050
      Thanks! that was easy enough!
        The cage drivers will love you as you go by. Those of us old enough to remember radio interference will stick with resistance caps.
        • b.walker5
          • Feb 2009
          • 1745
          • Invercargill, New Zealand
          Why, I dont have a radio on my bike, doesnt affect me....
            My thought exactly!
            • BigRed
              • Mar 2010
              • 265
              • Ottawa, Ontario, Canada
              Just in case...
              I've read that the radio interference from no-resistance caps can interfere with computer controlled ignition systems. If you find you've got problems, you can use spark plugs with resistors, and it's the same as having a resistor in your caps. I don't think that this is actually an issue for our vintage bikes... I think it's more of a concern with TCIs or fuel injector systems that use a real computer. May give you a nice edge when someone pulls up beside you his 200HP fuel injected supersport
              I've been looking for non-resistor caps to use with the Iridium plugs that I've bought that have resistors.
              • dbeardslee
                • 4385
                • Maineville, OH
                I run the non-resistor caps with the iridium plugs (only available w/resistor). I got them at a local autoparts store that handles NGK plugs. They had to order them special, but they got 'em. Mikes XS also lists the non-resistor caps, but I don't know if they're in stock.
                • WMarshy
                  • Apr 2009
                  • 2402
                  • Mexico NY
                  Well, I went onto NGK's site and decided that I want Cap Part# LB05FP for cylinders 1 and 4, and Part# XB05FP for cylinders 2 and 3. The LB's are $1.90 each and the XB's are $4.40 each. Unfortunately, they want $15 to ship $10 worth of parts! I know I can get the LB's locally for under $2.00 but no one has the XB's on hand. I searched on ebay and found a guy that has 4 XB's, starting bid is 0.99 and his shipping is $15 ...WTF Seems like flat rate shiping would be chaper than that. I was thinking about budding on them anyways to see if I can get them for $16, which would be a fair price. Anyone have a chaper supplier for these caps? I figured I would check NGK first but it looks like I might be able to get them cheaper anywhere else at this rate.
                  '79 XS11 F
                  Stock except K&N
                  '79 XS11 SF
                  Stock, no title.
                  '84 Chevy K-10 "Big Blue"
                  • dbeardslee
                    • 4385
                    • Maineville, OH
                    Mikes XS has the 90 degree for $3.50 ea. You really don't need the long 45 degree caps - the 90's will work on all cylinders assuming you have enough high tension wire to reach.
                    • WMarshy
                      • Apr 2009
                      • 2402
                      • Mexico NY
                      I want the long caps b/c I plan on cutting off the ends of the wires and I dont thing I will have enough left to use the short 90's... Im going to check to see how much the local shop can get them for before buying online. Thanks though.
                      '79 XS11 F
                      Stock except K&N
                      '79 XS11 SF
                      Stock, no title.
                        Well for now I stuck with the old caps (which were pretty much new anyways) and they are 5K ohms so I wont interfere with your radio for the time being!
                        • Ivan
                          • Jul 2008
                          • 2524
                          • Hutchinson KS
                          They will if you are talking on your cell phone!!!!
                          Sunday, I saw a guy on a dual sport riding through town with his cell phone in his left hand yaking away, and his right hand was a lit cigarette. At least he was ATGATT, with his baseball cap turned backward and his khaki shorts and sandals, and of course the ultimate protection of a cutoff T-shirt.
                          Ich habe dich nicht gefragt.
