Strange rubber tube...where's it go?
  • brcree
    • Mar 2010
    • 388
    • S.C.
    Ok I have a 81 sh mod. after getten it home and looken it over I saw a small 1/8" thin walled rubber hose comming from the back of the trainy...its on the top......it has a flat metal clamp with a small bend and a mount hole in it. The clamp is curved at one end and is around the hose. Can any one tell me where this goes? Just under the batt. area.
    At this time:
    1985 Goldwing Innr.
    1976 cb 750 cafe racer
    2007 vtx 1300
    81 sx 1100 s h
    81 sx 400 special
    That is the vent to the middle drive. The bracket you mentioned mounts with the bolt that holds the top air box mount in place. Look under the gas tank, there is a spot for it.
    • brcree
      • Mar 2010
      • 388
      • S.C.
      strange tube
      Ok, what does the tube connect to?
      At this time:
      1985 Goldwing Innr.
      2007 vtx 1300
      81 sx 1100 s h
      81 sx 400 special
        Nothing, it is a vent. It just sits in that bracket under the tank.
        • brcree
          • Mar 2010
          • 388
          • S.C.
          tube
          Gotya....thanks man! great info spot here!
          At this time:
          1985 Goldwing Innr.
          2007 vtx 1300
          81 sx 1100 s h
          81 sx 400 special
            The middle drive vent hose goes from the vent in top of middle drive up to front upper center connection of air box.
            • brcree
              • Mar 2010
              • 388
              • S.C.
              hose
              Thanks Moto.............you guys are the best!
              At this time:
              1985 Goldwing Innr.
              2007 vtx 1300
              81 sx 1100 s h
              81 sx 400 special
              • Crazcnuk
                • 2980
                • Hinton, AB, Canada
                Actually the main crankcase vent goes to the center of the airbox. A much larger hose...
                '05 ST1300
                  Yep, the Crankcase breather hose is about 5/8-3/4" hose OD, it hooks to that center spot in the air box. On the older bikes (78-79) the float bowl vents form the carbs go to the smaller holes on each side of the air box.
                  The middle drive vent just sits open to atmosphere in that bracket under the tank.
