If you have leaking valves or broken rings the reading wont change much, if they all good the reading will be noticably higher.
The 'wet' test will always give higher results but if the results are only marginally higher the the "compression" is escaping through the valves (adding oil does not affect valve seating).
If it improves significantly then the rings are suspect.
