A whole lot of problems all rolled into one!
    So to start off, I have a 78 XS11. everything is stock as far as I know.
    The bike will start right up and idle nice at about 1000. When you pull the throttle it will start to rev up to about 1500 and then the bike will bog down and start to sputter. If you hold the throttle open the RPMs will climb very slowly. Once it hits about 5000 the bike will take off normally again, but if you hold the throttle up there it will again start to sputter and slow itself back down.
    Compression test: 1-110 2-110 3-80 4-90 (not looking good)
    Coils: Primary-3.3 at the TCI and 1.5 for each coil individually. I cannot get a reading got the secondary. I know I will at a minimum have to put new wires on the original coils, I just dont know how (help?)
    Hopefully tomorrow I am going to pull the valve cover off and check the valve clearance (what should I watch out for when I do this).
    What else should I be looking at/for?
    Thanks
  • b.walker5
    • Feb 2009
    • 1745
    • Invercargill, New Zealand
    Check the ignition advance in the left side crankcase cover, sound like it's sticking or the vacuum advance isnt working.
      Ok, that will be one of the first things that I will do in the morning!
      • dbeardslee
        • 4385
        • Maineville, OH
        The New Wires in Old Coils tech tip has a pretty good step by step. To give you an idea of how much material you actually have to remove from the coils, they should look something like this when you're done -
        • tarzan
          • 1700
          • Chandler,Az.
          This may sound silly, but did you hold the throttle open when you did the compression test.Because if you didn't you will have low readings.
          80 SG XS1100
          14 Victory Cross Country
            • 5069
            funny compression
            If you just got the bike and it has been in "storage" for a while, the compression numbers may actually improve after you ride it for a while.
              I did not hold the throttle open, I can try it again doing it that way later.
              Yes I have only had the bike for about 2 1/2 weeks and it pretty much has not been used for about 12 years.
              • WMarshy
                • Apr 2009
                • 2402
                • Mexico NY
                If you can, warm up the engine first just by ideling it. Then check your compression with WOT.
                '79 XS11 F
                Stock except K&N
                '79 XS11 SF
                Stock, no title.
                '84 Chevy K-10 "Big Blue"
                • dbeardslee
                  • 4385
                  • Maineville, OH
                  If you can't get it warmed up, you can also try pouring a small amount of oil into each cylinder prior to testing. That will help the rings to seal about as well as their going to, and should provide a 'good' reading. Afterwards, it's going to smoke like you're fogging for mosquitos until it burns off the oil, but such is the price of accuracy .
                  • Winterhawk
                    • Jun 2004
                    • 684
                    • Missouri
                    Makes a huge difference with the throttle open while crsnking to check Compression.
                    • WMarshy
                      • Apr 2009
                      • 2402
                      • Mexico NY
                      IMHO I do not agree with dumping oil into the cylinders prior to testing. It will always indicate a higher compression than what it would otherwise. It has nothing to do with accuracy and everything to do with fooling yourself. Your engine doesnt normally run with that much oil on the cylinder walls so why would you do that? Should I put some sawdust in my valve cover to quiet down the cam noise?
                      '79 XS11 F
                      Stock except K&N
                      '79 XS11 SF
                      Stock, no title.
                      • b.walker5
                        • Feb 2009
                        • 1745
                        Hmmm... now theres a thought .LOL
                        But seriously the oil in the bore thing is an old school test to eliminate broken rings, and bad valves from the equation. First do your test dry, with WOT and then put a couple of cc's of oil in each bore and do it again. If you have leaking valves or broken rings the reading wont change much, if they all good the reading will be noticably higher. Never use oil for your first reading because as you've said, you'll get a false positive.
                        • dbeardslee
                          • 4385
                          • Maineville, OH
                          When the motor is running it's got plenty of oil on the underside of the rings, and it works it's way between them. When you let it cool down the oil is going to run away from the rings, and they won't seal as well. Putting a small amount in will compensate.
                            Update
                            I warmed the bike up and redid the compression test. new numbers were: 1-100 2-95 3-120 4-120.
                            I also pull the left cover off and was checking the vacuum advance. It seems to be moving freely. I watched it as I revved the motor and the advance moved with the RPMs. There was a little rust on the center rotating piece that I buffed off with some emery cloth. It seemed to be running a little better after I got rid of that little bit of rust (not sure if it had anything to do with that though).
                            Any other ideas or suggestions?
                            • ManagerMike
                              • Mar 2010
                              • 445
                              • S.E. Michigan
                              May I offer a clarification please?
                              When conducting a compression test, the first test is performed 'dry' and the first reading is discarded (ambient air got in there when you pulled the spark plug out). WOT is not required, but it will get you to the max compression reading with fewer rotations and therefore less strain on the battery and starter (always remove all plugs for the test for the same reason).
                              The need for a 'wet' test comes into play if and when you find low compression on one or more cylinders, adding oil and retesting (again twice) will then give you insight as to where the loss of compression is originating.
                              The 'wet' test will always give higher results but if the results are only marginally higher the the "compression" is escaping through the valves (adding oil does not affect valve seating).
                              If it improves significantly then the rings are suspect.
                              If the engine in question has been mothballed for an extended period, then it needs to be operated for a few thermal cylcles (warmed up and cooled off) to 'reseat' both the rings and valves before a meaningful evaluation of performance can be obtained.
                              Hope this helps.
                              '78 E "Stormbringer"
