wierd carb/rpm problem
  • the108penguins
    • Apr 2010
    • 130
    • Gainesville, Florida
    I've gotten so far as the bike runs now, not great but it runs .I've taken it for a few short runs to feel out any problems and after shifting into, riding, and shifting out of gears the rpms wont come down all the way. It hangs up around 2.5k-3k. I know it's not a throttle cable problem or a problem with the springs/pivots that are moved with by the throttle because they always return to neutral position when I let off the accelerator. Also the #1 cylinder doesn't seem to be firing at all or if it is it's really rich, cause it's header barely gets hot while the other headers, are peel your flesh from your fingers if you touch them hot.
    I still need to adjust/shim the valves, and the carbs are not synced or colortuned or anything just barely st at the same level with a feeler gauge.
    Any ideas anyone on what's going on with it?
    79 XS1100 Special
    Kerker 4-1, Pods, BS34 old style carbs, plastic floats, 147.5 mains, progressive rear suspension (restoring)
    Sounds like your having carb issues. Synchronization is important for idle setting. I'd get the tuning and synching done, then see what happens.
    • randy
      • Dec 2003
      • 4521
      I think you answered your own question..
      • the108penguins
        • Apr 2010
        • 130
        i figured that's why the idle isn't coming down but why is the #1 cylinder so much cooler than the others?
        79 XS1100 Special
          As to no 1, look at the plug and that may tell you some things.
          Even so, when your checking the header temps, is it after it has idled for a bit? If so, then idel adjustment may help it.
          • the108penguins
            • Apr 2010
            • 130
            well I ran it for a short time with the exhaust headers off and holding my hand in front of ex-ports 1 and 2. Even right from the start the exhaust from #2 was much hotter than #1(what #1 was putting out was about as warm as a fart)
            79 XS1100 Special
              What does the plug from no 1 look like? It can tell alot about what the problem may be.
                Like 98.6 degrees F? Hey, maybe it is alive! :-)
                • the108penguins
                  • Apr 2010
                  • 130
                  here's what plug 1 looks like
                  the rest aren't as dark
                  79 XS1100 Special
                    That plug is running pretty rich. Could be your issue with number one going cold at idle anyway. Although it does not look like it is fouling out.
                    • XSokieSPECIAL
                      • Jun 2009
                      • 1631
                      • Tulsa, OK
                      The miss at low RPMs is a sign of low compression. Have you checked that?
                      Maybe a bent valve?
                      JAT
                      However a syc might cure it.
                      • the108penguins
                        • Apr 2010
                        • 130
                        the valves are alright (or they'd better be, I just replaced them ) the compression is 120 on 1,2 and 3 and 125 on 4. It also has a hard time starting but that points to poorly tuned carbs too. so I guess it going to be a bit of work tuning them coming up.
                        79 XS1100 Special
