when should i mod the 2nd gear?
  • cheezy
    • Apr 2010
    • 71
    i flipped my bike over today and pulled the pan off. the thing looks perfect! the lands where the shift forks ride aren't even shiny yet. the transmission was working fine before it was parked. so i guess my question is, should i tear it down the rest of the way and cut down the gears, or just flip the washer, or just leave well enough alone until i actually have an issue? thanks!
    1981 xs1100 midnight special
    1983 750 midnight maxim
    resurrected:
    1977 goldwing
    1980 cb750
    North central Wisconsin
  • petejw
    • 2269
    • sydney australia
    how many miles are on the bike?
    personally if theres nothing wrong with it and
    it all looks good id leave it alone.
    pete
    new owner of
    08 gen2 hayabusa
    former owner
    1981 xs1100 RH (aus) (5N5)
    zrx carbs
    18mm float height
    145 main jets
    38 pilots
    • cheezy
      • Apr 2010
      • 71
      sorry, it's an 81ms with 16k mi on it.
      resurrected:
      1977 goldwing
      1980 cb750
        Leave it for when the issue arises, unless you just want the practice.
        • tinman905
          • Aug 2007
          • 946
          • Orangeville,Ontario ,Canada
          If it ain't broke don't fix it !!!!!!! I 'm sure there s many other things that can keep you busy fixing ,mod'in or cleaning
          BDF Special
            I would go ahead and do the washer swap on 2nd gear. I would think that may save you from going back in again.
            There are a number of these bikes that have gone 80k miles without ever needing the fix (I know of one with its original owner that has not). So you may be that lucky.
