i flipped my bike over today and pulled the pan off. the thing looks perfect! the lands where the shift forks ride aren't even shiny yet. the transmission was working fine before it was parked. so i guess my question is, should i tear it down the rest of the way and cut down the gears, or just flip the washer, or just leave well enough alone until i actually have an issue? thanks!
when should i mod the 2nd gear?
how many miles are on the bike?
personally if theres nothing wrong with it and
it all looks good id leave it alone.pete
new owner of
08 gen2 hayabusa
former owner
1981 xs1100 RH (aus) (5N5)
zrx carbs
18mm float height
145 main jets
38 pilots
[url]http://www.youtube.com/watch?v=3pA8dwxmAVA&feature=mfu_in_order&list=UL[/url] -
Leave it for when the issue arises, unless you just want the practice.81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.Comment
If it ain't broke don't fix it !!!!!!! I 'm sure there s many other things that can keep you busy fixing ,mod'in or cleaningBDF Special
Dyno tuned to 98 hp at the rear wheel.Comment
I would go ahead and do the washer swap on 2nd gear. I would think that may save you from going back in again.
There are a number of these bikes that have gone 80k miles without ever needing the fix (I know of one with its original owner that has not). So you may be that lucky.Life is what happens while your planning everything else!
78 XS750Comment
