my forks seem soft, do yours?
2004 RCM-50GL 2008-2010, Don't ask, don't tell (don't really know) -
When in doubt, knock 'em out!
I will not argue with idiots. They will only try to drag me down to their level and beat me with experience.
Not quite Geezer,
Ever look at a cage tire with bad shocks? Both situations can lead to cupping or uneven wear.'81 1100 MNS - "Midnight XSpress"
Original except:
Big JohnComment
That tool
You can get some up to 150cc at your local vet. They may not even charge you and the tip should be the same.'81 1100 MNS - "Midnight XSpress"
Original except:
Big JohnComment
True, but highly unlikely unless tire is out of round or severly out of balance. Theres alot of other factors that enter into the equation, specially today using radials on our newer bikes. Radials likely not being used here, but is just an added factor on our newer bikes. LACK of a fork brace on the XS's combined with NOT using tire manufacturer's reccomended max. pressures along with heavy front braking and tire cord design and configuration WILL cause cupping on the front tire. If it would pertain to this thread and not a hi-jack, I can give you results of addressing three of those four areas with a NEW tire as each area was addressed.81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.Comment
In 30 years of running ATF in my forks, I've never had a front tire cup. Then again, I also balance my tires.
One thing that cinched it for me when when the companies that sold fork oil started offering an ATF weight. You need to tune the fork oil to how you ride and ATF has always worked for me.
GeezerHi my name is Tony and I'm a bikeoholic.
The old gray biker ain't what he used to be.Comment
well im not about to get into a debate about
tyre wear and suspension, theres plenty of informative
stuff on the net.
pete
new owner of
08 gen2 hayabusa
former owner
1981 xs1100 RH (aus) (5N5)
zrx carbs
18mm float height
145 main jets
38 pilots
[url]http://www.youtube.com/watch?v=3pA8dwxmAVA&feature=mfu_in_order&list=UL[/url]Comment
