How to lock the bike........
  • mmarquis
    • Oct 2009
    • 12
    • currently arizona
    Does anyone know the correct way to lock the xs1100 , I turn my handlebars to the side and then i insert the ignition key and try to turn it to lock it but nothing happens , i had a honda once and it locked similarly , so i know how it should work but it's not working, i inserted the ignition key and pushed down and it goes down but i can't turn it to lock. Maybe someone has input ( no pun intended) on this.
  • WMarshy
    • Apr 2009
    • 2402
    • Mexico NY
    I dont think you have to hold the key pushed into the lock. Just push the key in all the way, let go, turn the handle bars left, and turn the key left... Should do the trick... Gotta watch out you dont walk away with the running lights on though...
    '79 XS11 F
    Stock except K&N
    '79 XS11 SF
    Stock, no title.
    '84 Chevy K-10 "Big Blue"
    • Eric_XJ
      • 56
      • Columbus, Ohio
      Originally posted by WMarshy
      I dont think you have to hold the key pushed into the lock. Just push the key in all the way, let go, turn the handle bars left, and turn the key.
      I thought it was to the right ?. On the XJ the lock is on the left side of the frame near the forks. Easier to get to by turn the bars to the right.
      Not sure on the XS, thought they were the same in that regard.
      -Eric
      82 XJ1100
      Mods:
      Mac 4 to 2 with turn out's
      • WMarshy
        • Apr 2009
        • 2402
        • Mexico NY
        On the XS the bar lock is part of the regular ignition to start the bike...not on the neck. Its been a long time since Ive used it but IIRC you dont need to keep the key depressed into the lock when you turn it... There are two stages when you turn it counter clockwise, I think lock then Lock+running light.
        '79 XS11 F
        Stock except K&N
        '79 XS11 SF
        Stock, no title.
          The lock that is built into the ignition switch can be activated by turning the handlebars either full-right OR full-left. Then, using the key in the ignition switch in the OFF position, press the key down into the switch, so it depresses past the face of the swtich. Then, while releasing slowly, turn to the LEFT. That will cause the metal peg to emerge from the bottom of the switch, and lock the steering head in the direction it is turned.
          Wmarshy is correct about the lights. Be careful not to turn the key all the way to the left, or that will leave the tail lights on and drain your battery!
          • WMarshy
            • Apr 2009
            • 2402
            • Mexico NY
            I knew it was some funky combination of depressing it and turning it counter clockwise.... They are about as complicated as a chineese finger trap. Once you do it right you wont forget it.
            '79 XS11 F
            Stock except K&N
            '79 XS11 SF
            Stock, no title.
