kleem
  • Filter
  • kleem
    has anybody used this product and did it work for you?
    82 xj1100j
    4-1 header
    k&n air pods
    accel coils
    progressive rear shocks
    dyno jet kit
    79 xs1100es (love of my life) passed away
    __________________________
    fast is never fast enough
  • #2
    Is that the chinese pronunciation for kreem?
    • #3
      If youre asking about KREEM, gas tank liner. Yes Ive used it and had 1-1 results, 1st time was my '68 motto guzzi, worked great, 2nd time was an '82 yamaha vision, not so good, but it had rust holes in it, big ones.
      '79 XS 1100F
      • #4
        I haven't used Kreem, have used POR15. Was really impressed with the POR15. I believe it has a more elastic quality to it. It was easy enough to use. If I'd been paying more attention I'd have used the POR tank cleaning product too. It is a whole lot nicer to your tank and uses some of the rust to help prep the tank rather than beat it up like the acid I used did.
        Good luck and take your time.
        Bothell, WA
        1980 XS1100SG
        • #5
          For my money you can't beat Caswell Plating's phenol novolac epoxy gas tank sealer. Problem with Kreem is that it's chemical resistance isn't that great. If you run a lot of seafoam or acetone, it can deteriorate the lining. Not going to happen with Caswell Plating's stuff. It's like putting a plastic tank inside your metal one. Good stuff, and relatively easy to work with. Just follow the instructions, and make sure you've got bolts (with a little wd-40 on them) in all the holes when you coat.
