you gotta be kidding me (crank seal)
  • boediddly
    • Dec 2009
    • 50
    • columbus,oh
    I've been waiting for a week for my left side (ignition side) crank seal (oil seal)and now bike bandit is telling me they're unavailable. I mangled the last one getting it out and its the last thing I need to ride my xs. where do you guys get your seals from and/or can someone give me the dimensions of that seal?Any help would be appreciated.
  • XJOK2PLAY
    • 2099
    • Skiatook, Ok.
    I recently redid mine. Got mine from the local Yamaha dealer. Both sides.
    2011 Kaw Concours 14 ABS
    • WMarshy
      • Apr 2009
      • 2402
      • Mexico NY
      You call all the local Yamaha shops? If they didnt have one they might be able to tell you what the dimensions are... If they do have it and it seems expensive you could still try to get the dimensions and do a cross ref to find one..?
      '79 XS11 F
      Stock except K&N
      '79 XS11 SF
      Stock, no title.
      '84 Chevy K-10 "Big Blue"
      • boediddly
        • Dec 2009
        • 50
        • columbus,oh
        I actually got this same seal from bike bandit 6 months ago but I needed a new one now the all the dealerships are telling me its discontinued but one parts place can look it up by dimensions
          • 8767
          If you haven't split the cases, you'll never get the factory type "lipped" seal in there. Without splitting the cases, a standard 32X48X8 seal from a bearing house (no lip) will work for you.
          • jmnjrpa
            • Jun 2009
            • 863
            • Lewisville, Texas
            most
            of the seals are available at a good bearing house. In most cases +/-1MM in width won't hurt. Also they are a lot cheaper than from the bike shops or yamarobbers.
            Check here http://www.benefiscal.co.uk/index.php for sizes and give your locals a call!
            Original except:
            Big John
            • Ivan
              • Jul 2008
              • 2524
              • Hutchinson KS
              I just got some double lip seals from CPC bearings in wichita KS. If you'd like I can order in another one and ship it to you or you can call them. Should be able to google their number. They are on Old Lawrence Road. The seal was roughly $3.50
              Ich habe dich nicht gefragt.
              • boediddly
                • Dec 2009
                • 50
                • columbus,oh
                gonna order them from cpc thanks guys
                • XJOK2PLAY
                  • 2099
                  • Skiatook, Ok.
                  Boediddly,
                  BikerPhil's correct about the lip on the seal...
                  But, there's a couple of ways to do it w/o splitting cases that work just as well:
                  1) Grind the outer lip portion down on a bench grinder smooth w/ the rest of the outer diameter, apply a good sealer... (I used Yamabond) and it'll tap right in w/ no leaks.
                  2) I've been told you can simply flip the seal around and it'll still work, but I haven't tried this method.
                  I have tried method 1 w/ no problems.
                  I had to do this for the LH (timing cover) side. The Yamaha seal for that side had the lip. I've also recently replaced the RH side (alternator) seal from Yamaha as well... it had NO LIP on that side. The 2 seals had 2 different item #'s, too.
                  Also, another notorious place for an oil leak on the RH side is below the alternator... oil galley plug has an O ring there. There is a thread, do a search for 'oil galley plug'... important tips and a good mod Trbig describes as well.
