Gear Oil
  • benxs1100
    • 92
    • Somerset, Pa
    Gear Oil
    According to the Clymers it is calling for GL4 but I couldnt seem to find any of that. Everything I saw was GL5. What should I run in my middle and final drive?
    '79 XS11 Special
    MikeXS Pods
    Green Coils
    80/90 weight FULL SYNTHETIC hypoid gear oil would be prefered. Any auto parts store will have it. You can use synthetic in the gears, but a lot of people have problems with their clutches slipping if they use it in their motors. Some don't though?
    • benxs1100
      • 92
      • Somerset, Pa
      Thanks for the response!
      '79 XS11 Special
      MikeXS Pods
      Green Coils
        Before you drain your middle drive (If you haven't already) make sure you can remove that filler plug.
        • benxs1100
          • 92
          • Somerset, Pa
          Yeah it comes out. I had it out to check the level before I rode it home the first time.
          '79 XS11 Special
          MikeXS Pods
          Green Coils
          • Ivan
            • Jul 2008
            • 2524
            • Hutchinson KS
            FWIW, GL-5 is the modern iteration of GL-4. Its just a specification really and the oil has to meet that spec in terms of performance criteria. GL-5 is higher spec than GL-4.
            Ich habe dich nicht gefragt.
            • Guy_b_g
              • May 2007
              • 790
              • Beverly Hills, Florida
              There was at one time a consideration about GL-5 vs GL-4, in that early GL-5 oils had a reputation for attacking brass, bronze and aluminum due to corrosive effects of the EP (Extended Protection) additives. This has been pretty much addressed over the years though, from what I understand.
              I wouldn't use an old can of GL-5 that has been in my garage for several years in my middle drive, personally.
              Guy
              '78E
              • WMarshy
                • Apr 2009
                • 2402
                • Mexico NY
                Sooooo... skip the discount GL-5 oil that needs a can opener to open it with?
                '79 XS11 F
                Stock except K&N
                '79 XS11 SF
                Stock, no title.
                '84 Chevy K-10 "Big Blue"
                  NSFW....
                    Ah those were the days.
                    Maxim Phil
                      Hey Phil, yes they were. I just recently went hunting around in my buddy's old service station in Georgia for old full cans of oil from waaaay back, no luck tho.
                        I do recall when you needed a can opener to open up the oil. When it was really a CAN of oil. Of course those were the days you could pick up old beer cans along the road and make a tennis ball cannon out of them. Try it now and the can explodes and the ball goes no where.
                          Campbells soup cans are still perfect...
