It all depends on which bike (or rear wheel) you have. The standards that we're discussing here have two spacers. If you have a special, or have swapped to a 16" special wheel, you only have the one. Same thing goes if you swap a standard 17" wheel onto a special, you'll now need the two spacers.
You also need the 'torque bracket' that was used with the wheel, as it's different too.
'78E original owner
'78E original owner
but nothing worked. I was pretty disgusted with it.
