Tunning Issue
+ More Options
Posts
  • MrOzz
    • Aug 2008
    • 782
    • Massachusetts
    Tunning Issue
    I been having a little issue tunning my carbs lately. Just can get them just right. After reading a couple of posts I am wondering if these holes at the end of my mufflers are suppose to be there. Looking at them I have a odd feeling that the PO drilled them. If he did then I am not getting enough back pressure and that might be part of the tunning issue.
    Thanks again all for your help.
    1980 XS 1100SG
    Dyna 3 Ohm Hi Output Coils
    Pod Filters
    DynoJet Kit
    T.C.'s Fuse Block
    V-Max Auto CCT
    Those are not factory holes. It is actually not at all uncommon for this to be done to open up the exhaust alittle and give the bike a bit of growl.
    Thunderstruck had the same size holes and twice as many per side. Never caused me any real tuning problem except I always had a bit of a pop on decel no matter how I tuned it. HTH
    • MrOzz
      • Aug 2008
      • 782
      • Massachusetts
      Thats part of the issue. Pop on deceleration.
      1980 XS 1100SG
      Pod Filters
      DynoJet Kit
      T.C.'s Fuse Block
      V-Max Auto CCT
      • tinman905
        • Aug 2007
        • 946
        • Orangeville,Ontario ,Canada
        Those holes shouldn't cause you any problems setting the carbs. Popping can also be caused but an exhaust leak somewhere. If not your a bit too lean . Make sure your idle screws are set about the same then try turning your idle screws out 1/4 to 1/2 turn and see if that helps.
        Check your carb boots for leaks . Make sure your vacuum ports on your carb boots have a tight plug on them ,that is often over looked but easily fixed.
        BDF Special
