Checking the plugs
  • Fix
    • May 2009
    • 384
    • Lake Orion, MI
    Checking the plugs
    I apologize for the bad phone pics, but I wanted to get everyone's opinion on my plugs color.
    I'm thinking I might be a touch lean all around, they look more white to me then tan. What say the gurus?
    Mike C
    Lake Orion, Michigan
    '78 XS1100E
    Here I am! Where are you?
  • Yotassan
    • Aug 2009
    • 13
    • Vassar Mi
    yes it does look lean too me....but I tend to run mine on the rich side....might be my monitor to your phone pics tho too....is it me or does the third pic / plug straight white??
    1981 xs1100sh ( new project )
    1978 kz650sr
    God is great...Beer is good....people are frikkin crazy!!!
    • Fix
      • May 2009
      • 384
      • Lake Orion, MI
      Screwy phone pics, they're all about that white.
      Mike C
      '78 XS1100E
        Pics are a bit grainy. If they are white white then it is running lean, especially if the electrode is deteriorating as one of them looks to have happening.
        If it is a grey color and no damage to electrode, that is more normal.
        • WMarshy
          • Apr 2009
          • 2402
          • Mexico NY
          I seem to post this vid a lot... Its a good one.
          The color of the insulator does not indicate your mixture, only the "base ring" around the insulator at the very end of the threads. All look like you are getting plenty of fuel. And you can read the heat range on the "tang" or ground to the electrode. NGK has some good information about reading plugs also. Its worth taking a look.
          '79 XS11 F
          Stock except K&N
          '79 XS11 SF
          Stock, no title.
          '84 Chevy K-10 "Big Blue"
          • Winterhawk
            • Jun 2004
            • 684
            • Missouri
            Highway riding using unleaded gas will cause them to look lean. If it runs good and doesn't pop on decel I'd call it good. #3 looks a little lean compared to the other 3. Check the fuel level and or mixture screw.
            • Fix
              • May 2009
              • 384
              • Lake Orion, MI
              Thanks for the video Marshy, I'm looking at it now.
              It does pop a bit on decel, that an earmark of running a little lean? I'm going to have to search on what to do if it is lean apparently.
              After watching video: Hmm, I do have some pop on decel, but according to that video I may be rich more then anything. Curiouser and curiouser.
              Mike C
              '78 XS1100E
              • WMarshy
                • Apr 2009
                • 2402
                • Mexico NY
                A pop is different from a back fire... I know mine runs a little lean b/c below 55 degrees F, mine has no power untill about 4000 rpm, it pops and sputters like when I open the throttle. Usually I end up running it on half choke on cold days, at least to get'er off the line... Either case, ya just have to back the mix screw out some. Im going to try a 1/4 turn at a time and test it...
                '79 XS11 F
                Stock except K&N
                '79 XS11 SF
                Stock, no title.
