ok my xs 1100 79 had a bad switch ( the switch that stop run stop stwitch) so i change that now my bike wont run..... please i need help....
this is what i have done i change the switch, trace the wires and even my start switch is good, run stop run stich is ok aswell...
check the starter relay switch ok test it by volt meter and even put a screw driver to start the starteer so the satreter work as well...
trace wire down farter and continutity is ok....
if anyone has any ideas of what can be the problem let me know thanks
