Rear Master Cylinder
  • Toolmaker Tim
    • 671
    • South Bend, Indiana
    I just diassembled my rear master and found a couple cracks in the plastic reseivoir. They aren't leaks, but they are close. Anyone know of a way to repair the plastic part or know of where I can get one?
    1979XS1100SF
    K&N's and drilled airbox
    Jardine 4in1
    Dunlop Elite 3's
    JBM slide diaphragms
    142.5 main jets
    45 pilot jets
    T.C.'s fusebox & SOFA
    750/850 FD mod.
    XV 920 Needle Mod.
    Venture Cam Chain Tensioner
    • 8930
    You could probably get one from member Andreashweiss, send him a PM. I don't think they're available new anymore, but I could be wrong.
    • CatatonicBug
      • 6117
      • Clinton, UT
      Even the parts fiche doesn't list the palstic reservoir as a separate item. Looks like it all came as one whole Master Cylinder unit.
      • Toolmaker Tim
        • 671
        Andreas is great, but I was wondering if anyone knew of a quick fix. If I spend any more money on this bike SWMBO is going to make me sleep in the garage. I just bought new plastic floats, VX920 valves and seats, rear master cylinder rebuild kit, and a set of Dunlop Elite 3's. It's not leaking, so I may let sleeping dogs lie. I have a nice piece of aluminum setting on my bench at work, maybe I could machine one up. Don't really need to see through one to see the fluid level.
        1979XS1100SF
        Jardine 4in1
        Dunlop Elite 3's
        142.5 main jets
        45 pilot jets
        750/850 FD mod.
        XV 920 Needle Mod.
          For that matter, just put some RTV over the cracks on the outside of the reservior. That way it will not leak down if it does go through, but will not let the stuff get into your brake system.
