shims make me sad
  • nemesis71
    • 12
    • ohio
    shims make me sad
    What other valve shims will interchange with XS 1100
  • rpgoerlich
    • Dec 2007
    • 643
    • Katy, Tx
    Some Yamaha Dealerships will exchange for what you need.
    If you can't find what you need check here:
    Richard
    • randy
      • Dec 2003
      • 4521
      BMW's and Kawasaki's are also 29mm.
      Which ones do you need? We have a shim library. We exchange by mail. Only cost is postage.
      • XSokieSPECIAL
        • Jun 2009
        • 1631
        • Tulsa, OK
        I've heard the Ford Taurus SHO engine is built by Yamaha and the shims are the same size but come in a greater variety of thicknesses and are CHEAPER.
        AFAIK
        • tadtl1
          • Mar 2010
          • 98
          • Auburn Mi
          taurus engine shims
          Hi,
          I am sure that the early Taurus SHO engines were built by Yamaha, but dont know at what year they changed. Based on the difficulty of obtaining the shims overall, it may very well be worth checking further into it. My dealer wanted thirteen bux a shim as I recall, and stated that reusing others was ok, but didnt have any used ones.
          80 MNS , Georgefix pods , crossed fuel lines, no octy, inline filters, Daytona handlebar, custom seat, Hardley 19 muffs
            Just remember that Suzuki made a 29.5mm shim, so take a set of calipers with you to be sure. You can't even hold the both together and tell the difference, it just won't quiiiiite fit in the bucket.
            • XSokieSPECIAL
              • Jun 2009
              • 1631
              • Tulsa, OK
              Tad.......
              There is always the forum library too:
                Yep, I to got the 29.5 mm shim before, it will not go in. I found a local bike shop that has a complete set of shims and sold me what I needed at $2 or $3 a shim.
                  Wow I am not looking forward to checking my valves.....
                  • XSokieSPECIAL
                    • Jun 2009
                    • 1631
                    • Tulsa, OK
                    Relax nate
                    It ain't as bad as it sounds.
                    • Winterhawk
                      • Jun 2004
                      • 684
                      • Missouri
                      AFAIK
                      Coll I have a Yamha SHO that I need to do the vavle adjustment on. I have some Yamaha Motorcycle shims. Good to know this, thanks.
