Throttle lock/Cruise control ?
Tags: None
Might try a crampbuster.
they're cheap and really take a load off of your hands, which lessens the strain on the arms...at least for me. Plus, lifetime guarantee. I picked one up for 5 on closeout at the local shop.
2004 RCM-50GL 2008-2010, Don't ask, don't tell (don't really know) -
Greg, I've got one of those exact same kits on my honda shadow and it works great! I tried that velcro paddle looking thing that wraps around your throttle grip and uses the palm of your hand designed to maintain your throttle position. That kinda worked ok. I still had the trouble of my hand and arm wanting to go numb (back problems), etc because your still putting a strain on your wrist.
I installed that throttle lock you found and love it! It took a quick second to fine tune it but it truly does work great. I can set it and take my hand completely off the grip and let it rest for a minute.
I bought mine at a local bike shop and it ran me about $35 bucks. I hope this helps.
Lanny1979 XS1100 SpecialComment
Thats the name I was thinking about......Crampbuster. It didn't work so well for me. Just my two cents.Might try a crampbuster.
I will admit that I have yet to take it for more than 20 minutes since I got it this week, but it sure felt good for those 20.
2004 RCM-50GL 2008-2010, Don't ask, don't tell (don't really know)Comment
I have a rubber version of a crampbuster, called a Throttle Boss. I didn't like how big the crampbuster is, so the small profile appealed to me. Plus, it was only $13.
AND I have the Vista Cruise control (actually just a throttle lock). It was $25.
-H. FordComment
Yea Dale, I looked at the cramp buster and it looks like it would be OK for short runs where you had to slow down and speed up a lot and it's cheap enough I might just get one because I can.
lwburnham......I see your fairly new to the forum.......welcome, your in the right place.
That is the kind of positive input I was looking for. I think I'll get one.
However......If this thing doesn't work we will attack you like a bunch of wild ravenous dogs and devour you in an unforgiving deluge of biting negative comments..........................JOKES
..........not really.
Greg,
I have the throttle locks Bug showed on his post and they work great. I'm even able to lay back against the sissybar/backrest for a little while and stretch my back. But for the extra $5 the JCWhitney ones really look nicer.1980G Standard, Restored
Kerker 4 - 1
850 Rear End Mod
Automatic CCT
1980GH Special, Restored
'82 XJ1100 (Sold)
Automatic CCT, RC Engineering 4 X 1 Exhaust, K&N Pods, #50 Pilot Jets, YICS Eliminator. Sorely missed.Comment
Wild ravenous dog attacks.......well sh*t......I'll set the traps out again - Thanks for the warning!!!Yea Dale, I looked at the cramp buster and it looks like it would be OK for short runs where you had to slow down and speed up a lot and it's cheap enough I might just get one because I can.
I actually don't like the JCW version, because it puts a bar across in front of the right controls, limiting access to the start button. It's just too bulky IMO. The Vista one is nice and slim, and fits into the tiny space already there between the grip and the right control housing. I had to trim down the rubber flange on my right grip by about 1/2", but once it was installed, you'd never know it wasn't always there.1980 XS850SG - Sold
-H. FordComment
Is that one y'all easy to operate? Seems to me the Vista Cruise would be easier with just a thumb.Comment
the bottom throttle lock that bug showed,
comes standard with my 81 rh, so i can assume
this wasnt fitted on the bikes in the states.pete
new owner of
08 gen2 hayabusa
former owner
1981 xs1100 RH (aus) (5N5)
zrx carbs
18mm float height
145 main jets
38 pilots
[url]http://www.youtube.com/watch?v=3pA8dwxmAVA&feature=mfu_in_order&list=UL[/url]Comment
You sure about that?? The parts fische does not show it as a stock item. Something tells me the PO may have fitted one on yours, and it just LOOKS like it belongs there.1980 XS850SG - Sold
-H. FordComment
CB,
You could be right, i just checked on my parts
bike and theres not one fitted to it, but i thought i remembered
reading somewhere that it was a stock feature for my
model bike, so now im not too sure.
pete
new owner of
08 gen2 hayabusa
former owner
zrx carbs
18mm float height
145 main jets
38 pilots
