Colortune
  • samm895
    • Apr 2010
    • 48
    • Northern Virginia
    Colortune
    Where is the cheapest place to buy a colortune and what size do I need for a 79f? I really need to get bike sorted out soon.
    1979 XS11 Standard
  • XSokieSPECIAL
    • Jun 2009
    • 1631
    • Tulsa, OK
    Least expensive one I've found...........
    • CatatonicBug
      • 6117
      • Clinton, UT
      It's actually cheaper to get it directly from Morgan Carbtune. Only 35gbp + 3GBP shipping. That works out to $56.27 total.
      • dbeardslee
        • Nov 2007
        • 4385
        • Maineville, OH
        Okie's price on a colortune looked pretty good - I think I paid around $85 for mine. You can also get them bundled with a carbtune for 90 english pounds from Morgan's.
        I didn't mean to be redundant, Bug - you just type faster than me .
        • XSokieSPECIAL
          • Jun 2009
          • 1631
          • Tulsa, OK
          I've just been waiting to have an extra $60 that doesn't have to go for food or to keep my house powered up to get one.
          I'm a little leery though after hooking up the one John had at MoM and all it did was make the engine misfire.
          • dbeardslee
            • Nov 2007
            • 4385
            • Maineville, OH
            The thing I like best about the carbtune is its portability. The whole setup fits in a case about the size of a carton of cigarettes. It isn't any more accurate the my gauges, but it isn't any less accurate either. The thing you have to watch with the carbtune is that all the rods are moving. They can get a little sticky if you've had carbs backfire while it's connected, in which case it may have needed cleaned. Speaking of which, I need to clean mine .
            • MrOzz
              • Aug 2008
              • 782
              • Massachusetts
              You need the 14mm one. Either direct from Morgan sometimes E-Bay.
              1980 XS 1100SG
              Dyna 3 Ohm Hi Output Coils
              Pod Filters
              DynoJet Kit
              T.C.'s Fuse Block
              V-Max Auto CCT
                • 8893
                Those Colortunes seem to work ok on some bikes, not so good on others. It helps if you alter the gap on the plug, I've found out, maybe a bit closer than how it's normally set up.
                • dbeardslee
                  • Nov 2007
                  • 4385
                  • Maineville, OH
                  Sorry - I think I misunderstood Okie's comment. I have noticed that the colortunes are much easier to read when connected to hot coils as opposed to stockers. When I get one that's got a weak spark I usually put the plastic sleeve over the plug so I can see the color better. JAT
                  • Montreux_Blue
                    XS-XJ Guru (Deceased)
                    • 1143
                    $59.95 US + $7.95 Shipping = $67.90 US
                    http://cgi.ebay.com/ebaymotors/Gunso...motiveQ5fTools
                    Famous Myspace quote:
