1st,2nd,4th and 5th gear fix...
  • the108penguins
    • Apr 2010
    • 130
    • Gainesville, Florida
    ok so now that I've gotten my gears ground and put back on the shaft it was time to put it all back in the bike. this was the hardest part as many have said. But I've found a few things that might help out a bit. first is that it makes it really hard if you try and put the shift fork shaft in before the counter shaft, leave it out till you get your gears in. pop the clutch-side shift fork (stamped with a c on one side) up above the other gear shaft close to where it is supposed to go and also put in the middle shift fork. then when you go to put the counter shaft and gears in look at the clutch side of the shaft there should be a cir-clip holding on the last two gears if you slide that clip out towards the end of the shaft to give those last too gears some wiggle room that should help you to clear the top gears and the kick-start gear (if you have one) when you get it into the bearing on the clutch side tap on it gently till it's flush and that should set the cir-clip back in it's slot. at least that's how I got my gears in.
    I hope that helps.
    Thanks motoman for your tips and help now I can move on to tuning and other fun stuff. and thanks to everyone else on this forum you are an invaluable resource.
    79 XS1100 Special
    Kerker 4-1, Pods, BS34 old style carbs, plastic floats, 147.5 mains, progressive rear suspension (restoring)
      Glad to hear you got it all sorted penguin! I could hear a bit of frustration when you called the other day. Things are close up in there, no much room as I had the same frustration and slept on it. Next morning the shaft assembly all but fell in........go figure. Again, glad to hear you overcame "murphy". Your most welcome, glad to help!
