How to Test Ballast Resistor??
  • Mont
    • Dec 2009
    • 11
    • Central Montana
    What should a good ballast resistor read in ohms (off a '789 xs1100)? I thought I had a bad one, got another (used but supposedly tested), and it reads the same. Both read '0', the same as when I touch the 2 ohm meter probes together.
    BTW, the bike still doesn't start without jumping across the solenoid.
  • tinman905
    • Aug 2007
    • 946
    • Orangeville,Ontario ,Canada
    1.6 ohms + or - 10%
    BDF Special
