Middle Drive
  • bmur63
    • Apr 2010
    • 7
    • Orange County
    Middle Drive
    79xs11f
    Tonight I disconnected the Final drive and swing arm. While doing so, I discovered the Large nut on the middle drive was completely cracked off, keeping the final drive from connecting to the middle drive. I pulled the middle case out, and now im taking the 3 allen heads out to pull the gear.
    If the output gear/shaft are damaged, throw the whole middle drive away (or send it to XSChop for a chain drive conversion) and get another one. These, like the final drive, have an elaborate set-up procedure with a bunch of special tools and you're supposed to replace the gears as a set. You can't replace just parts of it....
    '78E original owner
    • bmur63
      • Apr 2010
      • 7
      • Orange County
      wow, I did not know that. THanks
        Hi '63,
        do not despair, go to the XS11 parts for sale forum and check the listings. Andreas Weiss always has a good selection of used parts and there are others too.
