Organic vs Sintered...
    .. Brake pads that is.
    Has anybody run sintered pads on their XS? I know the originals are organic, but the 'metallics' offer certain advantages and have become nearly standard on the newer vehicles. The main reasons I ask is I'm wondering about rotor compatability as not all rotor materials are equal, and the 4-piston calipers I'm swapping onto my bike used the sintered type as standard. I'd like to use the near-new pads that came with the calipers.
    Any input?
    '78E original owner
    I've used them with the XS calipers and rotors before and couldn't get them to stop squealing. YMMV
      The noise can usually be dealt with by using some 'anti-squeal' goo or 'shims' on the back of the pads; I'm more worried about the pads eating the rotors. If noise was the only issue you had, I'll at least give 'em a shot.
      '78E original owner
        If your gonna use the XS rotors, no worry as they are the hardest stainless rotors I've ever seen. No new scoot out there even compares to their hardness. Another of Yamaha's overkill on the XS models! Over the years have used EVERY make of pad and even some not made anymore on the XS11....no issue, although some heat up and adhere better than others based on material used as you well know.
          Originally posted by motoman
          If your gonna use the XS rotors, no worry as they are the hardest stainless rotors I've ever seen...
          I know they're hard (I polished mine, and it was a b***h), but they're not as hard as the HD rotors that the calipers are supposed to run on (also polished a set of those, and never did get as good a shine..). But if both you and Phil have had no issues with 'other' pads, I'll go for it.
          Thanks!
          '78E original owner
          • WMarshy
            • Apr 2009
            • 2402
            • Mexico NY
            I've read to use the copper sintered pads and stay away from the iron sintered pads... I just bought a full set of copper sintered pads and Im waiting to get time to install them on the rear...
            '79 XS11 F
            Stock except K&N
            '79 XS11 SF
            Stock, no title.
            '84 Chevy K-10 "Big Blue"
              Makes no difference WMarshy, these rotors will digest anything there squeezed with. Just for comparison, I ONLY use OEM on my honda ST1100, as anything other WILL trash the rotors. Tells me the XS11 rotors were way over kill for hardness just like most everything else on the XS11. Pretty much why I chose the XS Venturer over other models back then, and looks like the dern thing is gonna outlast me....lol.
                If your gonna use the XS rotors, no worry as they are the hardest stainless rotors I've ever seen. - - -
                Hi Motoman,
                dunno about hardest, the centerpunch dents you whack in 'em to start drilling seem to be as deep as in other stainless steel parts I've worked.
                What they are is as tough as an old boot.
                That's why you gotta use cobalt steel drill bits to make holes in them and why they are eff nigh impossible to re-surface to a good finish.
                • b.walker5
                  • Feb 2009
                  • 1745
                  • Invercargill, New Zealand
                  I use these. http://catalog.vesrah.co.jp/catalog/shape/SD-215.html Says their "Semi Metallic" and they have others that are described as "Sintered" and "Organic" so i'm not really sure what the difference is. New ones tend to squeel when first installed but it doesnt last long and Ive never seen any damage to the rotors. Seem to have plenty of Stop when required, even when low flying, and the price is reasonable so ive stuck with them.
                  • cywelchjr
                    XS-XJ Super Guru(Deceased)
                    • 4450
                    • Sacramento, CA
                    I know that even with the anti squeal compound on them, the sintered pads drove me crazy with squealing. Got so bad that when I took them off, I threw them as far as I could down the street (well one of them anyways) the rest I threw down on the ground in disgust. The sintered pads on the rear however, have been pretty good, and I think I'll leave those on. But on the front I'll stick with the organics, especially since they seem to give better braking on the front (not such a big deal on the back, I can put more force on the pedal than is needed even with the sinter pads anyways).
                    • cywelchjr
                      • 4450
                      • Sacramento, CA
                      I'll tell you what I wish I could find in brakes for the XS though, is some good ceramic pads like you can get for cars. I've had pretty good luck with them on cars, I'm thinking they might be good for MC brakes too?
                        Ceramic? Do as you may but they are NOT compatible with the stainless compounds of these rotors. Rotor compounds are different on the new vehicles so hence the ceramic pads. Use ceramic on older disc brake systems on autos and you will do more than cuss or pich them. Ceramic pads were introduced due to composition of new vehicle rotors, but not all applications apply. Perform excellent were reccomended, not good if it be your own choice and not reccomended application.
                          That's what the pads I have are; I would be a bit more leery of the iron ones...
                          '78E original owner
                            From the research I've found, the sintered ones are more specifically for racing applications, much faster speeds, much longer application times, much more heat build up, and that they(sintered) actually don't work as well under normal street use. They actually need to get heated up a bit before they grab as well, and so for that quick emergency stop, they may actually perform worse than organic or regular compounds. Now under heavy prolonged braking action....probably like what Tod/Trbig puts them thru in the twisties...then they may not fade like regular materials!?
                            Again, this was Internet searches regarding the differences between sintered and regular type pads on street bikes vs. racing machines, etc.! I do not have any real world experience with the difference. YMMV.
                            Would be nice to do a test with the regular type regarding breaking distances, etc., and then for those that get the sintered ones, repeat the tests to see if any perceptible stopping distances are obtained!? JAT!
                            • petejw
                              • 2269
                              • sydney australia
                              ive got these fitted all round on mine
                              and couldnt be happier, they dont squeal
                              and pull the bike up real well even at speed.
                              no problems with the wearing of the rotors either.
                              they do have to be bedded in well tho.
                              pete
                              new owner of
                              08 gen2 hayabusa
                              former owner
                              1981 xs1100 RH (aus) (5N5)
                              zrx carbs
                              18mm float height
                              145 main jets
                              38 pilots
