Castrol GT LMA synthetic Brake fluid
  • mack
    • 2411
    • Ontario, Canada
    Anyone used this? Is it any good?
    mack
    79 XS 1100 SF Special
    HERMES
    original owner
    81 XS 1100 LH MNS
    SPICA
    78 XS 11E
    IOTA
    https://youtu.be/wB5Jfbp6SUc
    https://youtu.be/RaI3WYHSuWA
    Frankford, Ont, Canada
    613-398-6186
  • Tropic-al
    • Nov 2009
    • 174
    • Tampa, Florida
    Castrol synthetic
    I changed my rear brake fluid to that type.
    After about 20 miles the rear caliper locked up. Rotor was real hot. Only after it cooled down for about 10 minutes did the caliper release thus allowing me to head back home without using the rear brake. I had to rebuild the caliper and this time put in dot 3 or 4. After checking with a friend at a Yamaha dealer, he said they don't put synthetic on older aluminum calipers as they have had that problem come up with a lot of them.
    However, I have read where some of the folks here have used it in their bikes with no problem.
    79 XS1100F.
    TC's fuse box.
    SOFA filter.
    Venture cam chain adjuster.
    Tkat fork brace.
    Progressive fork springs.
      Even the autozone DOT3 brake fluid is synthetic. I don't think it has anything to do with that...
        Likely wasn't the issue as Bug stated. Onle TRUE syn. is DOT5. Would not use in any old systems of any sort as it is not kind to the older rubber pieces composition.
