Trouble starting when cold.
  • skipper808
    • Aug 2003
    • 5
    • Kauai, Hawaii
    I have a 1981 xs1100sh. When first starting It, It runs rough
    I have to keep on the throttle for a little bit till it warms up a little or it dies. does anyone know why?
  • beechfront
    • 673
    • midwest
    i always have to choke unless it's really warm out. it used to be much worse until i replaced the plugs.
    • sixtysix
      No XS but XSive as can be!
      • 1958
      • Central New York State
      Are you using the choke? If so you need the carbs cleaned most likely.
      Gary Granger
        Re: Trouble starting when cold.
        Try using the choke with no throttle until it "wakes up." Then use half choke and free the slides by chacking the throttle a few times.
          Re: Re: Trouble starting when cold.
          I meant "cracking the throttle." You know...goose it!
          • fusionking
            • Feb 2003
            • 453
            • lake of the ozarks MO
            You know I think nowadays people have "fuel injection mentality" Carbs never ran as good when cold as injection does today. And actually these bikes require more thought than say auto carbs with automatic chokes. And when you really get down on it they don't even have "CHOKE" they have "enrichment"! And that's funny in itself cause that is more like injection. HMMM................I guess you gotta think CARB .......... be the carb, be the carb, be the carb...............
            Garry
            '79 SF "Battle Cat"
            outbackweld@charter.net
