Viragos And Their Swingarms
  • XSokieSPECIAL
    • Jun 2009
    • 1631
    • Tulsa, OK
    LOL.....got Glen Beck on in the garage?.......LOL
    • joceiphus
      Xsive
      • Oct 2009
      • 285
      • Tulsa
      The garage is also my mancave. The PO removed the big door and put a wall there.
      Joe
      78XS1100
      • joceiphus
        Xsive
        • Oct 2009
        • 285
        • Tulsa
        Hence the geetars.
        Joe
        78XS1100
        • joceiphus
          Xsive
          • Oct 2009
          • 285
          • Tulsa
          Well, here's a mock-up. It's gonna take a lot of work, but it adds quite a bit of length!
          Joe
          78XS1100
          • xs11lover
            • 1433
            • Montoursville Pa
            That looks like it may work nice. They are some big bars a few pick back. Don't your arms fall asleep?
            79 XS11 Special (Lazarus)
            79 DT 100
            • Brian_D
              • 355
              • Gardner, KS
              Looking good! Any issues with centering the swingarm and lining up the driveshaft and tire?
              After a long hiatus, I will be picking back up on my VStar 650 swingarm mod this summer (and fall, and winter)
              • joceiphus
                Xsive
                • Oct 2009
                • 285
                • Tulsa
                I'm Super tall!
                Joe
                78XS1100
                • joceiphus
                  Xsive
                  • Oct 2009
                  • 285
                  • Tulsa
                  Haven'y made it that far yet. I'll post any problems I run into. Good luck with your mod.
                  Joe
                  78XS1100
                  • joceiphus
                    Xsive
                    • Oct 2009
                    • 285
                    • Tulsa
                    Alright,
                    I'm gonna have to get some spacers for in between the swingarm and the frame. Spacers for the rear axle. A longer rear axle. Tap a hole in the swingarm for the brake assembly, and longer brake lines. Then, shave down the coupler ( I guess you would call it?) where the driveshaft plugs into the final drive about 3/16" And PRESTO!
                    I'm going to do something different with my seat rails, but I don't see any reason one couldn't do this mod and not cut the frame.
                    Here's a rough pic.
                    Works pretty good for being a different model bike, and ten years difference!
                    Joe
                    78XS1100
                    • petejw
                      • 2269
                      • sydney australia
                      thats looking joe,
                      what size rear tyre are you putting on it?
                      pete
                      new owner of
                      08 gen2 hayabusa
                      former owner
                      1981 xs1100 RH (aus) (5N5)
                      zrx carbs
                      18mm float height
                      145 main jets
                      38 pilots
                        • 5062
                        I hope your frame welds are good! I'd hate to hear about dragging bottom due to a fame failure!!!
                        • joceiphus
                          Xsive
                          • Oct 2009
                          • 285
                          • Tulsa
                          Originally posted by petejw
                          thats looking joe,
                          To be honest, I hadn't thought about it til you asked. I'll do some research.
                          Joe
                          78XS1100
                            I think if you run the XS11 FD (which I see you have mocked up), the widest tire you can fit will be 6.25". That assumes cutting away the swingarm to expose the driveshaft and zero clearence to the shaft. To gain any more, you'll need to space the wheel away from the FD somehow...
                            '78E original owner
