I was still going through parts today to continue building my 80SG.
Came across a issue trying to fit the rear caliper torque plate to the bushing on the swingarm.
First off I have 3 parts bikes, 2 - 80SG and a 79F.
Parts were stripped 3 years ago and stuffed in boxes, not organized
The plate I think is right for a 80SG is this one with the slot were it is supposed to go over the swingarm pin bushing ..
Is this the correct plate for a 80SG ?
According to the fiche, 79SF and 80SG use same plate..
79F has a little different style, with a elongated hole for the bushing instead of a open slot ..
The only rubber piece I found which appears to fit is this one.
Problem is, the plate slot will not go over the groove in the rubber bushing.
Slot in the plate is about 3/8" , the rubber bushing slot is closer to 3/4", and I think the rubber bushing will get toasted when trying to fit this plate over it ?
Do I have the correct parts here ?
As I said, these parts got boxed up 3 years ago, and never got labeled to which bike they came off of ..
thanks .
thanks .
