Fuel Filter Recommendations
  • dontlikeoc
    • Nov 2009
    • 173
    • Alhambra, CA
    I started thinking maybe I should put in fuel filters instead of worrying if the rust suddenly comes back one day inside the tank. Do you have any particular fuel filter recommedations?
    dontlikeoc
    1981 XS1100 Special Edition
    Alhambra, CA
    Several options, I chose to use the small tapered conical ones as they are small and just require cutting each fuel line where the most open area is and inserting. I also have longer fuel lines and cris-cross them, left petcock to right side, right petcock to left side. The extra length also allows me tho sync carbs using fuel tank turned around placed where seat goes and blocking it up a bit so as not to crimp lines when syncing carbs. Also not using the vacuum lines to open petcocks I rotate petcock valves to prime. Easy to do all this on a standard since there is no octy.
    • dbeardslee
      • 4385
      • Maineville, OH
      I use metal NAPA FIL 3027 inline filters. I had the plastic conical ones, but heat from the motor kept deforming them. They still worked and didn't leak, but I just didn't like the way it looked. The napa filters last a long time, and they flow plenty of gas - $3.99 ea. Here's what the FIL 3027's look like -
      • jimbyjimb
        • Feb 2010
        • 263
        • Seattle
        All I can say is as long as it isn't Fram you'll probably be ok. I have never used, or fathomed, a worse filter in my life. NAPA and CarQuest brands are good and usually made by Wix.
        1990 Ninja ZX-10. It's the Silver Surfer. HI-YA!!
        2006 Yamaha XT-225. Yep, I take it on the interstate. It's Blue Butt.
        1982 Toyota 4x4. 22R Cammed, 38/38, 2" pipe, 20R head with OS valves, performance grind and other fun stuff. It's Blue RASPberry.
        1969 Ford F-250 Camper Special resto project. 390 RV cam, Demon carb, Sanderson headers, 2 and a quarter pipes with Magnaflow mufflers. It's Blue Jay.
        • dbeardslee
          • 4385
          • Maineville, OH
          You're right on target - it's made by wix - wix 33027.
