In opposition to TC, I am a fan of the washer swap. As he stated, the Dremmeled gears will usually work fine without moving the washer for a while. But moving it adds much better gear engagement. I have done the fix and tore up first gear again where you can't swap the washer (Tried that once also) and have never tore up 2nd again. As deep as the washer swap lets 2nd/5th engage, I don't think it would be possible for it to skip again. By just grinding it, without swapping the washer, if it rounds off again, it will skip again.
I doubt there's very many that have done the fix and ended up back in there to fix it again. When you grind the gears, you're going through the hard case hardened surface to softer metal. That nice pretty bevel you cut... gets mashed down and disfigured fairly quickly. It may pull your gears together for a short time, but after that, you're back to just relying on the material engagement depth to keep them together. This is also probably the reason you don't see many problems that Randy was worrying about with unmatched surfaces of the gears from Dremmel grinding. They'll mash down to where they all hit fairly quickly. I still use a caliper to get everything as close as I can though.
Those worried about the gear rubbing on the C-clip for some reason.. it's the same, if not harder steel than the washer, and after having them apart again after the fix on several occasions, I've never seen any noticeable wear on the clip.
As to the innitial statement in this thread, it almost sounds like there's a gear alignment problem. Either a bent shift fork, as stated, (Remember these forks are numbered 1-3 with #1 near the shifter) or also make sure the bolt under your clutch basket that holds this shaft against the case hasn't backed out.
Good luck.
Good luck.
The only way to fix that would be to re-case-harden the dremmel'd gears. I don't think anyone's ever tried that, and I'm not even sure if it's possible...
