there ARE no kits available... for lowering, for air shocks, for this or that. yer only option is to fab/scrounge/buy/steal something. as you might guess, with the high seat level of the XS1100, lowering the tail end has been done quite a bit. the solution i hear about most is putting on a shorter set of rear shocks.
stock shock is 12.5" from eye-eye. there are concerns about going TOO low, as it puts unwanted pressure on the U-joint. i *think* 11" is the absolute minimum. dont quote me on that, as i havent done the mod.
hopefully, someone will chime in with more knowledgeable knowledge.
- dan
- thinker57@lycos.com
- SF/H/E/HD "Stray Bullet"
Wasn't there a post about Rob Reil making some shock relocating brackets for the bottom end of the shocks?
This might have been on the triples list though. I remember replying that I'd be interested in a set.
I'm 5'8" also and I tip toe both feet or (usually) have one foot flat.
I never feel unbalanced or unsure while stopped. I usually have my right foot up and tapping the rear brake (blinking my brakelight) as cages approach from behind while I'm stopped at a light. Fortunately the terrain is flat around here.
Pat Kelly
<p-lkelly@sbcglobal.net>
1978 XS1100E (The Force)
1980 XS1100LG (The Dark Side)
1999 Suburban (The Ship)
1994 Dodge Spirit (Son #1)
1968 F100 (Valentine)
Joe.....the way I lowered my 79XS is a little different. I built a new saddle---pan & all. Rider's saddle is about 1 to 1 & 1/2 inches above the frame. I'm 6'3" tall & the ride is a whole lot more comfy than the factory saddle. So actually, I only lowered the saddle height....no worry about stress on the U-joint.
I'm 5'3" to 5'4"; Sometimes 5'5" in my boots. My Midnight Special was too tall for me; Too hard to control at a stop on my tippie toes. Kept dropping her. So, I reduced the shocks as low as they'll go, but still too high. Then, I cut out oodles of stuffing from the seat. That gave me a lot more control and dropped the seat a couple inches for me. Need to cut down some uncomfortable metal in the pan, though. Pad with some towels. Earlier I was riding just no seat and a towel which was a perfect height.
Now, if only, I can drop the rear suspension another 1 to 2"....she'll be just perfect for me! Hard to find a lowering kit. Was thinking of fabricating one, but then saw the shorter shock options in here. Thanks.
If the happiest 2 days in a boat owner's life are when he buys and sells his boat, what of the motorcycle rider?
