Pickup coil interchange.
  • webbcraft2150
    • Sep 2002
    • 1605
    • AUSTIN.TX
    I find em for '79's, I find em for '81's. Nuthin specific to a '80. All the same? Nice set on Ebay for a '81 and a '79. Need some help here, I literally am running on borrowed pickup coils. Bike Bandit wasn't much help on part numbers.
  • kjohnson
    • Aug 2007
    • 202
    • Wetaskiwin, Alberta, Canada
    If you have a XS1100G, special or not, it looks like it is unique. but it could be compatible, just with very different part numbers.
    You can double check at http://www.benefiscal.co.uk/ to be sure.
    edit : the main part of the part number is the same, just the prefix is different. picture looks the same as well. might work? All I know is my XJ is quite different from that yet.
    K. Johnson
    -1978 XS750SF - brought back from the dead with carb
    triple clean and boots
    -1982 XJ1100J - brought back from the dead by
    replacing motor after throwing #4 rod
    -1985 XJ750XN - shim job, oil change, ride. not bad for
    $500 including new rear tire.
    • dbeardslee
      • Nov 2007
      • 4385
      • Maineville, OH
      The pickups (little black boxes) themselves can be swapped from any year. If you want to replace the entire pickup coil assembly you'll be good with a 78, 79, or 80. You could probably get an 81 to work too, but the slot for the rotor is a little different.
