I find em for '79's, I find em for '81's. Nuthin specific to a '80. All the same? Nice set on Ebay for a '81 and a '79. Need some help here, I literally am running on borrowed pickup coils. Bike Bandit wasn't much help on part numbers.
Pickup coil interchange.
Tags: None
If you have a XS1100G, special or not, it looks like it is unique. but it could be compatible, just with very different part numbers.
You can double check at http://www.benefiscal.co.uk/ to be sure.
edit : the main part of the part number is the same, just the prefix is different. picture looks the same as well. might work? All I know is my XJ is quite different from that yet.K. Johnson
-1978 XS750SF - brought back from the dead with carb
triple clean and boots
-1982 XJ1100J - brought back from the dead by
replacing motor after throwing #4 rod
-1985 XJ750XN - shim job, oil change, ride. not bad for
$500 including new rear tire. -
The pickups (little black boxes) themselves can be swapped from any year. If you want to replace the entire pickup coil assembly you'll be good with a 78, 79, or 80. You could probably get an 81 to work too, but the slot for the rotor is a little different.I think I have a loose screw behind the handlebars.
'79 XS11 Standard, Jardine 4/1, Dyna DC1-1 Coils, 145 mains, 45 pilots, plastic floats - 25.7mm, XV920 fuel valves, inline fuel filters, speed bleeders, Mikes XS pods, spade-type fuse block, fork brace, progressive fork springs/shocks, manual petcocks, 750 FD, Venture cam chain tensioner, SS brake linesComment
