#1 and #4 pipes glowing orange
  • justjoe
    • Apr 2009
    • 13
    • western North Carolina
    Bought a baskecase 1980 midnight special for 250.00.Spent the winter getting it together.After alot of work its now (in my opinion) a good looking bike.I replaced the rusted out pipes with a nice 4 into 2 chrome set.#1 and #4 go to the right and #2 and #3 go to the left.Took it out of the garage today and fired it up outside for the first time.I am getting a "POP" out of #2 and 3. #1 and 4 are glowing orange.I dont know about these bikes but I do know this cant be good.I did a search but couldnt find anything specificallly about this problem.Any help would be greatly appreciated.
    If those spagetti pipes are glowing orange, better remove and ship them to me!...eeekk, what some will do to win what virgins are left!
    • justjoe
      • Apr 2009
      • 13
      [QUOTE=motoman;271869]If those spagetti pipes are glowing orange, better remove and ship them to me!....................Nice try Motoman
      • tarzan
        • 1700
        • Chandler,Az.
        That would be a sign of being very lean on those two cylinders.
        Probably carb related.
        Although one set of coils fires 1 and 4 and the other fires 2 and 3, but I doubt that is your problem since they obviously fire.
        I would start by trying to adjust the idle air screws on 1 and 4 out, but I bet the problem is in the carbs. Like clogged jets or passages or low float levels.
        80 SG XS1100
        14 Victory Cross Country
        • CatatonicBug
          • 6117
          • Clinton, UT
          Take care of those pipes! If they are the Jardine spaghetti pipes, they are one of the more valuable sets of aftermarket pipes for these bikes.
          Popping is usually due to fuel/air mixture screws. There is a tech tip about adjusting by ear vs using a colortune plug. Not sure on the glowing pipes though... They definitely shouldn't do that!
          • jmnjrpa
            • Jun 2009
            • 863
            • Lewisville, Texas
            Those two are way too lean. You need to adjust your carbs. Other threads will show the way. Do a search.
            He said 4 to 2 and right to left, etc.. Did not see any mention of jardine spagetti pipes???
            Original except:
            Big John
            • justjoe
              • Apr 2009
              • 13
              Yes...they are Jardine spagetti pipes. Thanks for the help.Anybody have a set of rebuilt carbs for sale??
              • jmnjrpa
                • Jun 2009
                • 863
                • Lewisville, Texas
                in that case
                Just step away from the bike and no one gets hurt!
                Original except:
                Big John
                • dbeardslee
                  • Nov 2007
                  • 4385
                  • Maineville, OH
                  How long was it running before the pipes got red?
                  • justjoe
                    • Apr 2009
                    • 13
                    about three minutes or so..at idle which was around 2 grand
                    • dbeardslee
                      • Nov 2007
                      • 4385
                      • Maineville, OH
                      WOW! That definitely doesn't sound good. What do your spark plugs look like? I don't know if a restriction in the pipe could cause that, but it might be worth checking as the problem seems isolated to one exhaust. Mice like to climb up and build nests in places like that. JAT
                      • WMarshy
                        • Apr 2009
                        • 2402
                        • Mexico NY
                        Wow sounds link a melt down is on its way if you let it run like that for very long. Like others said, take your plugs out and try to read the color, white is lean and would make the exhaust hotter than a rich condition (black plug). You should eat, sleep, breath in the carb maintenance section for a little while as I think you need to pull your carbs off and go through them again. GL
                        '79 XS11 F
                        Stock except K&N
                        '79 XS11 SF
                        Stock, no title.
                        '84 Chevy K-10 "Big Blue"
                        • justjoe
                          • Apr 2009
                          • 13
                          When I get home from work today I plan on pulling the plugs out and see what thay look like.I never did go thru th carbs.The bike fired right up so I figured they were OK.Obviously I was wrong about that.All my previous bikes were Triumphs so this is all a new experience for me.It seems Im gonna get alot of help from the people here so she should be straightened out and back on the road soon.Thanks to all
                          • oseaghdha
                            • Aug 2006
                            • 1075
                            • N43.02.5,W88.14.2
                            Originally posted by justjoe
                            When I get home from work today I plan on pulling the plugs out and see what thay look like. I never did go thru th carbs.The bike fired right up so I figured they were OK.Obviously I was wrong about that.All my previous bikes were Triumphs so this is all a new experience for me.It seems Im gonna get alot of help from the people here so she should be straightened out and back on the road soon.Thanks to all
                            BZZZZZT!
                            FAIL
                            There probably 8,467 carb threads here. So no lack of reading material.
                            Those pipes are likely going to want you to go up a main jet size, as long as you are in there.
                            XS1100SF
                            XS1100F
                            • justjoe
                              • Apr 2009
                              • 13
                              Well the #1 and 4 plugs were starting to turn white.The #2 and 3 plugs were covered with black carbon.
