'79 xs1100sf shaft drive play/slap normal???
  • cadjawpondkid
    • Mar 2010
    • 7
    • york, pa
    throttle on /off /on low speed there is slap in drive train,,
    is this a normal characteristic or do i have a problem,
    it feels excessive,,(my old cx500 honda shaft drive does
    not have this slap!)
    any help to offer?
    thanks!
  • jmnjrpa
    • Jun 2009
    • 863
    • Lewisville, Texas
    Yep,
    Sounds like you may have a u-joint problem. There is also the chance of a rear drive issue. I'll leave you with other members who have worked on these areas. Have you put it on the center stand to determine where the slap is at?
    '81 1100 MNS - "Midnight XSpress"
    Original except:
    Big John
      • 8963
      If you're used to bikes with not much slop, this ain't one of them. Check things out though, u-joint, mid drive, final drive, driveshaft axle splines. Good luck!
      • Yahman
        • Mar 2008
        • 779
        • Salem, OR
        Check this thread out, it will give you some idea of the amount of play in these bikes.
        Larry
        82 XJ1100
        80 XS1100G (Project bike)
        64 Yamaha YA-6
        77 Suzuki TS-185
        • MindWebs
          • May 2009
          • 431
          • Baldwin, WI
          i've got the same bike....
          it does have some slop when you chop the throttle.
          if your worried and thinking it's to much then tear it down for inspection and
          greasing. all else fails you have done some needed maintenence on the bike.
          or you may find a bad U-joint, either way you have helped your bike out.
          i have torn mine down and i didn't find anything that was worn.
          Good luck
          • Yahman
            • Mar 2008
            • 779
            • Salem, OR
            Originally posted by MindWebs
            I have torn mine down and i didn't find anything that was worn.
            Same here, they're just like that.
            Larry
            82 XJ1100
            64 Yamaha YA-6
            77 Suzuki TS-185
