high idle/HAZZAA!!
  • usmc_scott
    • Mar 2010
    • 69
    • california
    high idle/HAZZAA!!
    well iv been sufferig from a high idle problem for a while now starts and runds at 2-3000 rpm pulling the carbs adjusting putting them back on only to find out...damn the stupid throttle cable is caught up and causing my probles. re adjusted the carbs slapped them on and bam lowest idle iv ever had 800-1000 rpm....
    so heres where the questions come in to play. what is the average idle for these bikes? i think 900 is a little high it stutters and dies when i try to do 700 rpm idle im testing with NO air filters by the way (dont worry! clean shop air!) but i do plan on running mikes xs pods or the cheaper ebay ones because im on a tight budget so is it now an air to fuel mixture issue i need to address or is it still a dirty carb/fuel starved/ stuck float w/e
    another tid bit. the right spark plug looked a little black the right looked tanned does the soot indicate rich mixture or is it oil? wont oil be shiney not just sooty?
    thanks for any input fellow xs'rs i will soon be hitting the streets! as the ginger kids on south park said- HAZZAA!!
    -xs1100 special
    -wife
    -daughter
    • 8800
    Shop manual recommends 1100 RPM idle. Sooty indicates rich condition or weak spark. If it was oil, you would see oil. You could try turning the idle mixture screw in 1/4 turn or so, that might help.
    • tw1980
      • Apr 2009
      • 662
      • Bend OR
      Sync the carbs before you set the idle mixture.Beg,barrow or steal some vacuum gauges.This might help.www.factorypro.com Terry
      1980 special (Phyllis)
      1196 10.5 to 1 kit,megacycle cams,shaved head,dynojet carb kit,ported intake and exhaust,mac 4 into 1 exhaust,drilled rotors,ss brake lines,pods,mikes xs green coils,iridium plugs,led lights,throttle lock,progressive shocks,oil cooler,ajustable cam gears,HD valve springs,Vmax tensioner mod
      • usmc_scott
        • Mar 2010
        • 69
        • california
        the carbs seem to be perfectly syched as far as i can tell. i did the bread tie trick and didnt have to adjust a thing really. iv only messed with the idle positions and then put it back on the bike untill i figured out the linkage was geting hung up..sigh...all that work for nothing. btw what are thoes stack things?? i said i was putting on pods. i dont think it would be wise to run without filters and go straight stacks...but it would look cool =)
        so..off igoto learn how to adjust the a/f mixture
        -xs1100 special
        -wife
        -daughter
        • GARTHXS
          • Nov 2007
          • 1631
          • Seattle
          bread tie
          this is only a bench sync , you need to do a proper sync , I have a morgan that I could help with , sorry I havent met you yet or I would let you borrow it , hit me up some time
          91 kwaka kz1000p
          Stock
          ( Insert clever quote here )
          • WMarshy
            • Apr 2009
            • 2402
            • Mexico NY
            There is some good info to read here about building your own and adjuting for maximum vac and also how to do f/a tune. Hope you have a min or two.
            '79 XS11 F
            Stock except K&N
            '79 XS11 SF
            Stock, no title.
            '84 Chevy K-10 "Big Blue"
            • GARTHXS
              • Nov 2007
              • 1631
              • Seattle
              im with 81xs
              on that topic, but you can make your own sync tool with some 1/8 inch id clear tubing 2 yard sticks and some zip ties , do a google search for diy manometer, I suggest the ones with tubes rather than the one with a single vac guage , way more accurate
              91 kwaka kz1000p
              Stock
              • TDodge7
                • May 2009
                • 246
                even being slightly out of sync can cause problems , the bread tie sync gets you close , but one carb could still be pulling harder than the rest , a proper sync tool will show you if one is off even a tiny bit . As far as tuning there is no point in tuning anything at this point if you don't have air filters on it , as soon as you add them your tuning will change and you'll be right back where you are now . Get some air filters , sync , then set your idle mixture , then sync again , then figure out if you need to change anything jetting wise by riding it and reading the plugs .
